Hey guys,
Looking for a little help/advice here. I bought some leather/heated seats from someone I found on here and swapped them in to replace my cloth seats around last October ('13). I have a 2004 N/A GP and the seats were from a.... maybe a 2005? I'm not really sure, but anyways let me get to the point. I swapped them in, hooked up all of the connectors as well as the new HVAC control unit from the parts car that the seats were from but the heat seats were not "enabled" in my BCM. I also had the BCM from the parts car so I tore up my dash and swapped it in! Voila! I had working heat seats!! Problem: No start. Couldn't get the security system to let me start the car (which has NEVER happened before). I ended up going to a dealer and having them program the BCM so I could start the car and it's been well ever since. Everything to do with that has been fine, no issues... That's really just the back story to my problem.
Here goes: My power door locks un-lock whenever I want them to (ex: with the fob or door buttons) but the problem is that they do NOT reliably lock. I can hit my lock button on the fob and it'll honk but not lock, same with the door switches. I might be wrong here but I believe that this is controlled by the BCM because this issue has been intermittent since I switched BCM's. I also NEVER had a door locking issue before the BCM swap. Before I go and buy a not-so-cheap new BCM, does anybody have any ideas as to why this is happening? Whenever I hit the door lock button/switch, I hear a clicking(relay I assume) in the area of the BCM. I can only hear it when the door locks don't actually actuate, but it might happen when they do actuate... it's just that the lock actuation is loud enough that I can't hear the quiet clicking from the dash.
Thoughts and input are MUCH appreciated! Thanks!!
- Ken
