Thread: A/C spits material out the vents when I go to cold on my climate controls
Results 1 to 7 of 7
  1. #1 A/C spits material out the vents when I go to cold on my climate controls
    Banned
    Jan 2013
    maryland
    Everytime I try to use my cold a/c its spit material like flakes or just anything why is this and what can I do? I replaced the blower motor what else should I check? Thanks!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: A/C spits material out the vents when I go to cold on my climate controls
    Aug 2013
    arlington, tx
    Have you checked your cabin air filter?
  3. #3 Re: A/C spits material out the vents when I go to cold on my climate controls
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by luckyg817 View Post
    Cabin air filter?
  4. #4 Re: A/C spits material out the vents when I go to cold on my climate controls
    cabin filter is located under the pass side cowl. it covers the hole where you can see the fan from the cowl area.
    if you dont have one in place there maybe dust, or even a mouse nest or was a nest. and its being blown out the vents.
  5. #5 Re: A/C spits material out the vents when I go to cold on my climate controls
    Aug 2013
    arlington, tx
    Yea what scottydoggs said. It sounds like you don't have one if it's blowing all that stuff in from the outside. It's a cheap easy fix too.
  6. #6 Re: A/C spits material out the vents when I go to cold on my climate controls
    or inside the hvac box its self, the nest could be on the cold side of the door, open the cold side and the nest could be flying out.
    does the air smell bad too?
  7. #7 Re: A/C spits material out the vents when I go to cold on my climate controls
    Aug 2013
    arlington, tx
    I hope theres not a nest in there...
  1. quick question about climate controls
    By hockeybawler in forum General Tech Discussion
    Last Post: 08-18-2012, 11:26 AM
  2. Storage bin climate controls swap
    By xbryxsetsfire in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2012, 03:34 PM
  3. Cold / hot air, all vents simultaneously.
    By Randy GP in forum General Tech Discussion
    Last Post: 10-10-2010, 08:19 PM
