Thread: Water sloshing in the dashboard
Results 1 to 7 of 7
  1. #1 Water sloshing in the dashboard
    Dec 2008
    Franklin TN
    Hello all,
    This is my first posting on the site and it is kind of a strange one to start my experience. We have a stock 2004 GT1 with the 3.8 that my son drives. It was my old company car so I have had it since it was new. Present miles are approximately 90K. Especially under moderate or above accelleration (or turning), there is a sloshing or wet suction sound in the central part of the dashboard. There is no coolant smell or evidence of a leak on the driveway or in the interior. Do you think this is a heater core problem or something else? While not a mechanic, I have been around cars and never heard this problem before. He says that the heater does not work all that well but based on what I have seen, it is blowing warm air. Any thoughts???
  2. #2 Re: Water sloshing in the dashboard
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    could be a water leak from the cowl into the heater box itself....
    there are a few threads on here about water leaks on the floorboards and in the dash.
    Id check the heater box, basically take out the glove box itself to get access under the dashboard, have someone rock the car a bit and the water should move for you to pinpoint it.
    Im sure the glove box comes out, just dont know how. Ive had this issue on the s-10s and s-15's ive owned in the past. hope it helps
    Welcome to GPF
  3. #3 Re: Water sloshing in the dashboard
    Dec 2008
    Franklin TN
    Thanks to all who have replied. The car is out right now so it will be later in the day before I can check things. I will look at the coolant level first - easy fix, hopefully. It makes sense as well given the sounds that it makes. I will post later today or tomorrow with what I find. Thanks again !!
  4. #4 Re: Water sloshing in the dashboard
    I live here. UR LOSN's Avatar
    Rockford, IL
    ^^^^^^ thats what I was thinking as well!
  5. #5 Re: Water sloshing in the dashboard
    Barksdale AFB, LA
    Your coolant is low. You need to check the level at the radiator (with the car cool). Don't rely on the overflow bottle since it doesn't tell you how full the system is. Open the radiator cap, and the coolant should be all the way to the top, about to overflow. If not, make it so.
    Then you should take it for a drive, then bleed it.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Water sloshing in the dashboard
    Odessa, MO
    Quote Originally Posted by Sabrewings View Post
    My thoughts exactly having experienced this first hand with another car I once had.
  7. #7 Re: Water sloshing in the dashboard
    Barksdale AFB, LA
    It would also explain any lack of performance from the heater.
  1. Water on floor
    By karkrazy1971 in forum General Tech Discussion
    Last Post: 12-22-2008, 08:24 PM
  2. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  3. Water in headlight...
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-14-2008, 03:37 PM
  4. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
