Thread: Help with 2006+ seat swap into 1998 seat belt issues
Results 1 to 10 of 10
  1. #1 Help with 2006+ seat swap into 1998 seat belt issues
    Banned
    Hello
    I got some seats from a 2007. I am having trouble with hooking the seat belts up. I notice on ebay that the seat belt retractors are different for the 2006+ models. Will the retractors from the new cars bolt into my 98? or does someone know of a solution to hook my current retractors to the 2007 seats?
    Also is the wiring different on the newer seats? .
  2. #2 Re: Help with 2006+ seat swap into 1998 seat belt issues
    You need to either reuse your current seat belts and retractors or get the complete set of seatbelts and retractors from the 07 and attempt to use them. You cant mix and max there specific to the car you pulled them from. Make sense?
    04 Comp G.
  3. #3 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Banned
    That makes sense for the rears. My specific problem is on the fronts, where the retractor connects to the lower part of the seat. All the threads I saw no body mentions any seat belt issues.
  4. #4 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Apr 2012
    Bancroft. Ontario, Canada
    This. You NEED to reuse the buckles off the (in your case) 98... And bolt them to the seat from the newer gp...
  5. #5 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Feb 2010
    TN
    I just wnet on ebay and ordered belts from a 97 and kept the buckles from the 07 on the seat you could try Junkyard as well
  6. #6 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Banned
    Quote Originally Posted by Speedy1973 View Post
    Roger that
    Still my problem is that I cant get my retractor to bolt to the seat. Swapping the buckle over looks to be no problem
  7. #7 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Banned
    04 and 05 are different from the 06+ seats, the retractors are different part #'s.
    Has anyone here put 06+ seats in a 97-03?
  8. #8 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Feb 2010
    TN
    Quote Originally Posted by Logan541 View Post
    Correction meant oredered belts from a 07
  9. #9 Re: Help with 2006+ seat swap into 1998 seat belt issues
    SE Level Member Elusive85's Avatar
    Sep 2011
    Flint, Michigan, United States
    It should look like this when it comes off.
    Elusive85
  10. #10 Re: Help with 2006+ seat swap into 1998 seat belt issues
    Banned
    I ended up doing a little cutting and drilling to make the 98 belts bolt on to the new seats.
  1. Replies: 1
    Last Post: 10-02-2013, 07:52 PM
  2. seat belt swap
    By Logan541 in forum General Tech Discussion
    Last Post: 10-27-2012, 07:11 PM
  3. seat belt ?
    By crewsn in forum General Tech Discussion
    Last Post: 04-17-2009, 10:19 PM
