Thread: shaking steering wheel after wheel bearing replacement
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: shaking steering wheel after wheel bearing replacement
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by sseilmnop View Post
    I have not heard of good ones going bad!! Find me 2 people, It's easy to find cheap ones going bad.
    I just replaced my left front SKF bearing, less than 2 years old; was growling bad.
    Speak up second person.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #22 Re: shaking steering wheel after wheel bearing replacement
    Aug 2013
    arlington, tx
    Quote Originally Posted by Bronco Boy View Post
    Haha. 1 down, 1 to go!
  3. #23 Re: shaking steering wheel after wheel bearing replacement
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    I had almost the exact same problem. I replaced my front left bearing, and a couple of days later I had a small vibration. I thought the car wash had knocked off a wheel weight, or worse that my new hub was bad. Then I drove almost 2000 miles in the next 3 days. By the time I got home, the small vibration was really bad. Some how my bad bearing (mechanically loose, not a sensor failure) messed up my alignment, and the result was this on my *REAR* tire. I was positive that I was going to find something wrong with the front end suspension or wheels themselves. I got 4 new tires and an alignment. Also had the crappy power stop front rotors turned as they had brake pulsation. Now everything is buttery smooth.
  4. #24 Re: shaking steering wheel after wheel bearing replacement
    seems the 04 up cars have a camber issue and wear out like that on the inside of the tire all the time. not a hub issue at all. defiantly not related to a front hub.
  5. #25 Re: shaking steering wheel after wheel bearing replacement
    Eau Claire, WI
    Sorry I wasn't more clear, that's actually my point. I think the hub messed up the alignment (or it was just off as the hub let loose), and the new hub made it more obvious since the front tire wasn't wagging around anymore. Which may have lead to one rear tire severely wearing suddenly. Could have all been a coincident for all I know.
  6. #26 Re: shaking steering wheel after wheel bearing replacement
    not a chance, that back wheel had its own issue for sure.
    each wheel has its own alignment, the front being out wont hurt the rear like that.
  7. #27 Re: shaking steering wheel after wheel bearing replacement
    Sweet seperated tire.
  1. GP 2008 shaking steering wheel above certain Speed
    By ibra0078 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2014, 11:49 AM
  2. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  3. wheel bearing replacement?
    By loganrick in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2012, 12:28 AM
  4. Steering wheel shaking a little after tire rotation
    By Haulero in forum General Tech Discussion
    Last Post: 12-08-2009, 09:56 PM
  5. Wheel Bearing Replacement. Question!
    By brownb66 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:04 PM
