Thread: P0171 Front Bank Lean
Results 1 to 10 of 10
  1. #1 P0171 Front Bank Lean
    Feb 2010
    Milwaukee, WI
    Alright, running out of hope with this code.
    It's a 2000 GT 3.8 and been getting this code for a couple months now. It is for the most part a steady light however it has randomly shut off for just a very split moment just a couple times over the months. Nothing seems wrong with the vehicle other then bad gas mileage.
    Idle is fine (around 850) Acceleration is fine. Everything seems just fine. No unexpected noises, just a SES light and bad mileage.
    Recently had the lower intake gasket replaced due to having an oil leak up at the front of the engine but appears that I may be burning through oil (though not enough to see smoke, just not seeing a leak and have to drop a quart in at least once before regular oil change)
    Since the SES light has come on, I have replaced:
    Upstream O2 sensor
    MAF
    Intake manifold
    Various vacuum lines
    Along with other various typical spring time tune up things (clean air filter, changed oil)
    Taken it to a couple different mechanics and basically been charged $100+ to have them reset the light and tell me to piss off.. not in the best mood with "mechanics" right now. Last one did tell me that the injectors appear to be all working fine but I'm not sure I believe him since he also told me they took it for "an extensive test drive to see if the codes would return" and apparently an "extensive test drive" only covers a tad bit over 1/10th of a mile.
    I have attempted the carb cleaner over the entire engine to see if there was a change in rpms to find a vacuum leak intake side but came up with nothing.
    I'm in hopes that someone may have any other ideas on what to look at to get fixed to solve this code. Because of it only being the front bank code and having no noticeable loss in power, I am not thinking it is fuel injector related and my last guess would be the front exhaust manifold gasket. Is there any good way to check this? or is that something I would be able to hear being a problem?
    Thanks for anyone that could give some sort of help with this, I'm getting tired of the SES light being on all the time.
  2. #2 Re: P0171 Front Bank Lean
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    what is the fuel trim at and are you on the same tank of gas? sometime bad gas can cause that code
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: P0171 Front Bank Lean
    Feb 2010
    Milwaukee, WI
    Quote Originally Posted by 00grandprixgtp View Post
    It's not bad gas, it's been a lengthy problem now and I don't have tools to check trim. However, after reading through a bunch of different posts and not even thinking of an EGR issue (figured that would be it's own code) I did nothing more then unplug it and on next start, the SES light was off. I don't get it, It doesn't make sense to me that unplugging the EGR would cause the light to go out on next start. I thought the system basically had to go through a few checks of the system to automatically shut off a SES light.
    Oh well, I plugged it back in but the light wasn't on when I restarted this time. Going to try and get the light to come back on and then unplug the EGR again to see if it goes out.
    Now, if it does have something to do with the EGR and since I'm not getting a code for it, would it be more likely that it has something to do with the lines that go into it or the EGR itself might be bad?
  4. #4 Re: P0171 Front Bank Lean
    Check your egr tube they like to crack and are hard to see without pulling them off the car
  5. #5 Re: P0171 Front Bank Lean
    Damn Smutts is now stealing my favorite fix.
  6. #6 Re: P0171 Front Bank Lean
    happened to me before lol
  7. #7 Re: P0171 Front Bank Lean
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    i have this code now after replacing rear o2 and bending back a bent exhaust.. i bet a cracked a pipe somewhere lol
  8. #8 Re: P0171 Front Bank Lean
    Rear o2 won't cause this code and unless the exhaust leak is before the front o2 that's not your problem
  9. #9 Re: P0171 Front Bank Lean
    I love it when folks replace o2's to not fix this one. It's teh O2's that are reporting the issue through the pcm.
  10. #10 Re: P0171 Front Bank Lean
    Medford, NY
    oh no i had a bank 1 sensor 2 code, replaced that and fixed it.. then the p0171 code came up after my o2 sensor was working again which showed me that i had a broken vacuum hose which was replaced and fixed the p0171.
  1. Codes P0171 Lean Bank One
    By Garry in forum General Tech Discussion
    Last Post: 02-07-2013, 05:10 PM
  2. fixed the p0171 lean condition
    By Erik Adam Rodriguez in forum General Tech Discussion
    Last Post: 01-27-2013, 10:00 PM
  3. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  4. P0171 - System Too Lean (Bank 1)
    By siege101 in forum General Tech Discussion
    Last Post: 04-28-2012, 07:48 PM
  5. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
