Thread: CV Axles
Results 1 to 18 of 18
  1. #1 CV Axles
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Are ZZP's stage 2 axles worth it? Also are there any other reasonably priced options.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: CV Axles
    Omaha, NE
    For the price, I have to say no. You can get duralast lifetime axles from autozone for around $70 each.
    Yeah, you may need to replace them (under warrnaty) slightly more frequently than ZZP S2, but for the savings, it's worth it in my opinion.
  3. #3 Re: CV Axles
    Oct 2011
    Toledo, OH
    What's the expected life on them? Pretty sure my axles have almost 100k on them.
    7"
  4. #4 Re: CV Axles
    I'm with spade, not worth there cost.
  5. #5 Re: CV Axles
    I've seen axles go 200K+ w/o issues and I've seen them go 20K. All depends on how much error was built into that axle.
    Factory axles do seem to fare better than replacements etc. I know a bunch of guys were going JY shopping for stockers when they would have issues.
  6. #6 Re: CV Axles
    Oct 2011
    Toledo, OH
    That would explain the $486 price for an OEM passenger axle on Rockauto.
    7"
  7. #7 Re: CV Axles
    Mercer, Pa
    I buy JY stock axles! I needed a new boot and it was the best option in my opinion.
  8. #8 Re: CV Axles
    And..what's your local JY get for an axle? Score!
  9. #9 Re: CV Axles
    Jan 2009
    ny
    My stock axles have a little play in them, wondering how hard it is to rebuild them. I drive hard, don't want a poor quality axle to break and/or destroy my transmission. Hopefully someone will post where I can get a good factory replacement.
  10. #10 Re: CV Axles
    HUDSON
    I still have my original axels from my car. I replaced both at about 140k miles (boots torn). At the time it was just easier and faster to just install replacements. What I did in my spare time was order new boot kits from RA (came with boots, geese,clamps) and disassembled, cleaned and inspected all the balls and bearings and surfaces, and as it turns out there was very little wear on them, with new grease and boots they are still nice and tight/stiff. So now I have an extra set of spare axels should I ever need them.
    It is not that hard to clean and re-grease/re/boot, just make sure to keep the parts together and make it hospital clean before it all goes back together. I think I used a HAYNES manual for reference and the disassemble and reassemble.
  11. #11 Re: CV Axles
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Not sure how people destroy axle's so much I really think it's mostly from the motor mounts going out screwing up the geometry and binding the axle's I'd make sure to check and replace the garbage motor mounts these cars come with if you are having any axle problems.
  12. #12 Re: CV Axles
    Nov 2011
    NY
    Quote Originally Posted by addzradd View Post
    Not sure how people destroy axle's.
    Cause... razekar!
  13. #13 Re: CV Axles
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    When the boot rips and slings grease everywhere and 25k miles later you still don't care.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  14. #14 Re: CV Axles
    I break stuff selliott's Avatar
    Kansas City
    Zzp stage 1 CV= auto zone
    Zzp stage 2 CV = orielly
    Stock is better than both according to a very reliable source
  15. #15 CV Axles
    GTX Level Member crbquist's Avatar
    Massachusetts
    Napa axles are decent from what I've heard. Also, doesn't WBS sell rebuilt gm axles at a good price?
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  16. #16 Re: CV Axles
    Jan 2009
    ny
    Quote Originally Posted by crbquist View Post
    I just checked out the WBS site, looks like I may get them and some other things from there. Thanks.
  17. #17 Re: CV Axles
    Donating User Odi's Avatar
    Chicago South Suburbs
    Got moogs a year ago, they work fine.
  18. #18 Re: CV Axles
    Dec 2012
    troll land
    274k milles on my original cvs, two monthes boosted
  1. Will cv axles from a 01 gtp fit a 05 gtp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-01-2014, 07:52 AM
  2. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  3. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  4. Bad Axles?
    By lflylow in forum General Tech Discussion
    Last Post: 10-20-2011, 08:57 PM
  5. New CV Axles.
    By Brammer in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2011, 10:06 PM
