Thread: Help fast! lim gaskets in progress
Results 1 to 19 of 19
  1. #1 Help fast! lim gaskets in progress
    Ohio
    Ok im working on teardown to do lim gaskets. i have the 33 min vid an have been following that but for somereason they didnt show where to drain the coolant. im to the point where i need to. where is the drain plug at? i thought i knew but cant seem to find it.
    00 GTP demodded and forsale
  2. #2 Re: Help fast! lim gaskets in progress
    SE Level Member NEONNIGHT34609's Avatar
    Dec 2008
    florida
    lower part of the rad is where the drain is .. you will still need to change the oil after the job .
  3. #3 Re: Help fast! lim gaskets in progress
    Ohio
    on the bottom sides just under the fans? i looked there an couldnt figure it out thats where i thought though. an yea i know about oil. thats a bit down the road yet but thanks for the headsup on it.
  4. #4 Re: Help fast! lim gaskets in progress
    Oklahoma
    The drain plug on the radiator is on the drivers side, bottom part of the radiator, it can be a bit difficult to find, but its there. Alternatively, and quite a bit more messy, you can just pull the lower radiator hose and drain it that way.
  5. #5 Re: Help fast! lim gaskets in progress
    Ohio
    Ok i found the plug now. but how do you get it out it looks as though it requires some kind of special tool?
  6. #6 Re: Help fast! lim gaskets in progress
    Oklahoma
    Its a weird set up. I believe it takes a 3/8" extension (I guess it could be 1/4", but for some reason I remember it being 3/8"), just the square end of the extension, and you put that in and then twist and pull. Its a strange set up indeed, and it will come out with a little finagling. The new radiator I have has a wing nut on it and I like that SOOOO much more.
  7. #7 Re: Help fast! lim gaskets in progress
    Ohio
    O alright that sounds like alot easier than the suggestion i found googling that wasnt working which was needlenose pliers
  8. #8 Re: Help fast! lim gaskets in progress
    Ohio
    got it thanks syn
  9. #9 Re: Help fast! lim gaskets in progress
    Oklahoma
    Not a problem, let us know how it goes for you.
  10. #10 Re: Help fast! lim gaskets in progress
    Ohio
    Do i put locktite on intake bolts?
  11. #11 Re: Help fast! lim gaskets in progress
    Moore, Oklahoma
    I'd put on some thread sealer, not locktite.
    Shawn W. Larsen
  12. #12 Re: Help fast! lim gaskets in progress
    Ohio
    Thanks iron indian. Are there torque specs for them? or just get them tight?
  13. #13 Re: Help fast! lim gaskets in progress
    Ohio
    nevermind i got it found the torque specs page
  14. #14 Re: Help fast! lim gaskets in progress
    Barksdale AFB, LA
    I guess our radiators are different. Mine has a wing nut and is also shaped like a 3/4" hex head so you can just slap a socket on it. Twist a quarter turn and it drains out the drain hole in the bottom.
    2009 Subaru Impreza WRX STI
  15. #15 Re: Help fast! lim gaskets in progress
    Ohio
    ^ wish it had been that simple for mine. but anyway project is done. i had some setbacks on the way. had to get new injector o rings since mine were rock hard and also had to drive half hour away to get the 2 coolent seals that go on top of the lim between it and the blower cause that was the closest location that had 2 of them. after all that it was finished. started it up an noticed oil dripping onto the front header lookedf an the rockerbox gasket was hangin out in 2 spots not sue how it happened since i never touched it but my guess is had to do with another f#$% up by the dealer when they did the recall so then i had to go get a new rockerbox so did that put everything back on again an then finally the project was complete an now it runs a whole lot better.
  16. #16 Re: Help fast! lim gaskets in progress
    Oklahoma
    Congrats on getting it all done.
  17. #17 Re: Help fast! lim gaskets in progress
    Ohio
    thanks
  18. #18 Re: Help fast! lim gaskets in progress
    Dec 2008
    Lawndale, CA
    You may want to clean your stock coolant sensor. Mine stayed on after I did mine. Other than that glad to hear you got everything worked out.
  19. #19 Re: Help fast! lim gaskets in progress
    Ohio
    Thanks for the tip ill do that^
  1. replacing LIM gaskets. HELP!
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 06:22 PM
  2. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
  3. build in progress
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 06-11-2008, 07:09 PM
  4. work in progress
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2008, 07:29 PM
  5. reuseable gaskets?
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2008, 08:38 PM
