Thread: RPM Decreases Then Increases
Results 1 to 2 of 2
  1. #1 RPM Decreases Then Increases
    Apr 2014
    Minneapolis
    Hey guys. When I'm cruising down the road and I apply the brakes, the RPMs start to decrease normally, then it drops down to 700-900 RPMs, then jumps back up. It happens every 5 seconds or so. What could be the issue? Transmission? Air leak? Or is this normal. Thanks in advance.
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  2. #2 Re: RPM Decreases Then Increases
    Vacuum leak
  1. Tempature gauge increases when idling
    By M7x350z in forum General Tech Discussion
    Last Post: 04-20-2014, 05:51 PM
  2. Idle decreases when wheel turns???
    By roundbox52 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2010, 07:34 AM
