Thread: Installing New PLOG Exhaust Manifold - Help
Results 1 to 20 of 28
  1. #1 Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Hey guys. I have a 2000 Grand Prix GTP with about 117k miles on it. I got a new Powerlog exhaust manifold, and so I'm going to have to take off the old manifold. I got new studs and nuts for the new manifold, but since the stock studs and nuts are pretty old and rusty, should I be worried about them breaking off in the head? Should I use a lot of PB blaster before I take them off? What would be the best way of going about this? I'm fairly new to working with cars, so I want to be as careful as possible. Thanks in advance.
  2. #2 Re: Installing New PLOG Exhaust Manifold - Help
    Id spray them with pb blaster everyday for a few days... It sure can't hurt it. Breaker bar to loosen those studs and then finish using a socket. Where did you end up getting your studs from?
    04 Comp G.
  3. #3 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Thanks for the information. I got both the studs/nuts and the bolts for the crossover pipe from ZZP.
  4. #4 Re: Installing New PLOG Exhaust Manifold - Help
    Ahh that's what I figured. I went down to napa today to try to find them locally but had no luck.. Guess I'll add that to my next ZZP order.
    04 Comp G.
  5. #5 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    I tried that myself and had no luck either. ZZP ships them pretty fast though so theres hardly any waiting.
  6. #6 Re: Installing New PLOG Exhaust Manifold - Help
    Yea they're cheap from ZZP so I don't mind order them I just won't order them by theirselves but I need to place a order with them anyways so I'll keep that in mind.
    04 Comp G.
  7. #7 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Yeah man. Hey a few of my buddies are saying that there is a chance that the studs will snap off in the head. If I use PB blaster everyday for a few days before I install the new manifold, will that really lessen the chance? They don't think that will work.
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  8. #8 Re: Installing New PLOG Exhaust Manifold - Help
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    One other thing that might help is to let the engine heat up to operating temp and while hot break everything loose that you can, and soak them with blaster. This will allow the pb blaster to penetrate into the bolt holes, get around all the threads and lessen the chance of breaking.
  9. #9 Re: Installing New PLOG Exhaust Manifold - Help
    I didnt have a single problem removing any bolts from my 2000 GTP that spent it's entire life in MN.
    I re-use all studs and factory nuts when I did my headers like 3 years ago.
    I only snapped and broke the downpipe bolts because there wasnt anything left of them.
  10. #10 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Alright. I'll be using the PB blaster for the next couple days on the studs and nuts to get them ready, then before the uninstalling of the stock manifold, get the engine hot then blast it again, wait for it to cool down, then break em loose. Does that sounds like a safe procedure?
  11. #11 Re: Installing New PLOG Exhaust Manifold - Help
    Probably overkill to be honest with you I'll just spray it a few days before and go for it. I had no problem removing mine without using pb blaster only reason in ordering a few studs is because I misplaced them.
    04 Comp G.
  12. #12 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    One quick question, there are 5 studs/nuts, and 1 bolt right? or 6 studs/nuts all together just for the manifold.
  13. #13 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Alright. I'll keep you guys updated with how it all goes!
  14. #14 Re: Installing New PLOG Exhaust Manifold - Help
    I think there's 2 just studs on the rear header and the rest are stud/nuts. And in the front it's all stud/nuts but don't quote me on that. I ran 2 studs on the end if both the front and rear so they'll hold the gasket in place while you get everything else lined up. And honestly it doesn't really matter what you do.
    04 Comp G.
  15. #15 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Alright thanks. I just looked at how many there were and it looked like there was 1 bolt, but I may be wrong. I could still substitute that bolt for a stud and a nut.
  16. #16 Re: Installing New PLOG Exhaust Manifold - Help
    To remove the manifold.. keep in mind the bolts are in steel that is heated whenever you start the motor. They aren't rusty in the head. This isn't an aluminum head, and it's not a ford and they won't break unless you gank on them at an odd angle. I've taken out more exhaust bolts than any of us could count, I use no penetrant, if you want something different..run the motor and heat them up. The crossover to EM might snap if you don't loosen them equally. Spray those with a little pb and you should be fine.
  17. #17 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Stellar. Thanks for the tip! I'll definitely do that prior to the install.
  18. #18 Re: Installing New PLOG Exhaust Manifold - Help
    The worst case that typically happens is you don't loosen the crossover to front em bolts equally and you snap one. So what.. hit the hardware store. M8 X 1.50 thread. Done.
    Although I have spares on hand..lol
  19. #19 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Haha I'll keep that in mind. I got new bolts for the crossover to the em so in case they do snap, I have a couple extra.
  20. #20 Re: Installing New PLOG Exhaust Manifold - Help
    Perfect... now.. doing the job should take you less time than you have posting about it already. Go do it!
  1. Flow numbers Stainless PLOG and ported front exhaust manifold
    By usetaboost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2013, 10:10 PM
  2. Installing PLOG on 99 GTP
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2012, 05:40 PM
  3. need some help installing an exhaust
    By asite57 in forum General Tech Discussion
    Last Post: 07-23-2012, 12:42 PM
  4. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  5. plog and ported manifold
    By superv6 in forum General Tech Discussion
    Last Post: 05-08-2009, 06:34 AM
