Thread: Automatic Headlights?
Results 1 to 20 of 20
  1. #1 Automatic Headlights?
    SE Level Member JordanC's Avatar
    Feb 2014
    Rockwell, IA
    ok i know the trick for disabling the Daytime Running Lights..but how do u Disable the automatic headlights i want it to be manual (using the headlight switch)?
  2. #2 Re: Automatic Headlights?
    search for that, theres a bunch of threads that cover it. drl module in the dash needs to get unplugged and a fuse needed to be pulled.
  3. #3 Re: Automatic Headlights?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Backinblackgp.com has a way, I used it. You replace the photocell in the middle of the dash, next to the security light. With a 470 ohm resister.
    Sent from my Lumia 900 using Board Express
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  4. #4 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    and that shuts the automatic headlights off? cause everything i read on that page says that works on all up to a certain year...cause mine just chimes if i take the fuse out...even with the heat sink unplugged
    2002 Grand Prix GT 40th Anniversary Edition
  5. #5 Re: Automatic Headlights?
    May 2011
    Tampa FL near USF
    Pulling the heat sink will disable the drls, and the resister disables the auto head lights, at least that's the set up I have on my 02 GTP
  6. #6 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    ok ill try that out..
  7. #7 Re: Automatic Headlights?
    Donating Users
    Jan 2014
    West Virginia
    On my car, which is a 2000 GTP, all I did was pull the DRL fuse and it disabled both the DRLs and the Auto In feature. I've heard that some will still chime, mine didnt, haven't had any probs.
    Fixedwing1
    2000 GTP 3.8 S/C
    Kenwood / Infinity Audio: 17" Konigs w/ 245/50/17 Gmax tires: Headlight retrofit W/ Morimoto minis: Flipped dog bones
  8. #8 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    Where can i buy the resistor? None of the parts stores around here even know what it is lol.
  9. #9 Re: Automatic Headlights?
    May 2011
    Tampa FL near USF
    Radio shack or maybe a small hobby store
  10. #10 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    1 more question i found them but which one do i buy? there is a 3 different ones......one is a 470 ohm 1/2W 5% Carbon Film Resistor pk/5.....and a 1K Ohm 1/4-Watt Carbon Film Resistor (5-Pack)....and 470 ohm 1/4W 5% Carbon Film Resistor pk/5...
  11. #11 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
  12. #12 Re: Automatic Headlights?
    Dec 2012
    Where 4T65E's were born
    That will work.
    Sold.
  13. #13 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    is there a specific one to use?
  14. #14 Re: Automatic Headlights?
    Dec 2012
    Not really, you just need a certain resistance to mimic daytime.
    Sold.
  15. #15 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    ok thank you!!
  16. #16 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    it didnt work replacing with resistor its just made my headlights on all the time..
  17. #17 Re: Automatic Headlights?
    Dec 2012
    What year do you have?
    And get the photocell and measure the resistance when in the dark and that's the resistance you need in place of the resistor. I don't know why the one you used didn't work.
    Sold.
  18. #18 Re: Automatic Headlights?
    May 2011
    Tampa FL near USF
    Did u pull the heat sink for the drl's?
    Sent from my Lumia 900 using Tapatalk
  19. #19 Re: Automatic Headlights?
    Dec 2008
    Lawndale, CA
    Here you go.
    http://www.backinblackgp.com/DRL_TS_Kill.htm
    It should work. I did this in my brothers 03 and it worked.
  20. #20 Re: Automatic Headlights?
    Feb 2014
    Rockwell, IA
    i got it.... the resistor didnt work so i cute the wires off the resistor and just used it as a jumper wire and it worked..
  1. 2000 GTP VS BMW E39 BMW 540 Automatic
    By buickman104 in forum Track Sessions and Kills
    Last Post: 12-16-2012, 05:50 PM
  2. Disabling Automatic Headlights
    By asite57 in forum General Tech Discussion
    Last Post: 12-05-2011, 06:55 PM
  3. New to automatic trans
    By FeaR in forum General Tech Discussion
    Last Post: 10-17-2010, 01:02 PM
  4. Automatic Starter?
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 11-26-2009, 09:12 PM
  5. modding an automatic?
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-07-2009, 02:50 PM
