Thread: newbie here!!
Results 1 to 6 of 6
  1. #1 newbie here!!
    Apr 2014
    United States
    Hey guys im new here...just a tech question ...wifes got a 04 gran prix .. non sc..trans feels as it intermittently slips at low speed or initial accelleration from time to time ...no codes fluid and filters fresh .. anybody ever had this problem...70k miles ... never had catalytic converter replaced ... should of replaced it when i worked at the dealer...but never had an issue ... just asking befor i pull the trans...thanks all
  2. #2 Re: newbie here!!
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Cats are designed to last the life of the car between 5-8 yrs. If they go bad some problem in the engine caused. Don't know much about trannys , ok there was that one time in New Orleans, but back to your problem. I'd ck your solenoid.
  3. #3 Re: newbie here!!
    Try cleaning the MAF sensor, a really dirty MAF can cause transmission feeling issues.
    Clean the throttle body aswell.
  4. #4 Re: newbie here!!
    Apr 2014
    United States
    cool thanks Guys!!! is there a special cleaner for the maf???
  5. #5 Re: newbie here!!
    Dec 2010
    ATL,Georgia
    Yes its called MAF cleaner don't use brake cleaner or anything like that... it's too harsh
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  6. #6 Re: newbie here!!
    Apr 2014
    United States
    cool thank you .. ill let you guys know how i make out
  1. newbie
    By pink1221 in forum Introductions/Noob Questions
    Last Post: 08-01-2011, 09:06 AM
  2. 06 Newbie
    By setshot50 in forum Introductions/Noob Questions
    Last Post: 12-07-2010, 10:42 AM
  3. newbie
    By jrfighter in forum Introductions/Noob Questions
    Last Post: 12-04-2010, 07:15 PM
  4. newbie here
    By yellow600r in forum Introductions/Noob Questions
    Last Post: 12-03-2010, 07:57 PM
  5. Newbie
    By Gorgeous02GTP in forum Introductions/Noob Questions
    Last Post: 11-05-2010, 02:13 PM
