Thread: Oil Pan mounting bolt size/type
Results 1 to 6 of 6
  1. #1 Oil Pan mounting bolt size/type
    Jun 2013
    N/A
    I was snugging up my oil pan bolts last night to torque specs whilst doing an oil change and snapped one off.
    I extracted it and had a similar bolt laying around as it was late and all the parts stores were closed. I filled her back up with oil and all is well.
    Anyone know the exact bolt size/type the pan uses to mount? Peace of mind thing I guess for my next oil change so I can have it ready and swap it in. Thanks!
  2. #2 Re: Oil Pan mounting bolt size/type
    Pretty sure it's an M6 1.00 Like 30-35mm long
  3. #3 Re: Oil Pan mounting bolt size/type
    hangover park IL
    1/4" sae coarse thread 3/4"-1" uhl
    ~James~ Psychotic Gearhead
  4. #4 Re: Oil Pan mounting bolt size/type
    Looks like I was pretty far off...
  5. #5 Re: Oil Pan mounting bolt size/type
    hangover park IL
    and alum pans need to be a hair longer.
    yeah bill I aints kiddin when I mention how much the SII shares with its ancestors....
    our bare block is ALL SAE fasteners except for the accessory mounting points.
    its amazing how often ive seen the PS pump bolts crossthreaded from someone using a T cover bolt...
  6. #6 Re: Oil Pan mounting bolt size/type
    hangover park IL
    well to be fair if it was a 1/4" fine thread you woulda easily been able to cross thread an m6x1.0 in there
  1. broke a flex plate mounting bolt
    By vikingjrc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-24-2013, 05:53 AM
  2. Blower motor mounting bolt/nut size
    By quickster in forum General Tech Discussion
    Last Post: 08-11-2011, 11:21 AM
  3. Caliper bolt thread type?
    By 4birdman in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2011, 04:17 PM
  4. Caliper Mounting Bracket Bolt
    By Paintball0027 in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2010, 11:14 AM
  5. Bolt Size
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2009, 06:40 AM
