Thread: Where is the PCV location and why do my high beams turn on by themselves???
Results 1 to 5 of 5
  1. #1 Where is the PCV location and why do my high beams turn on by themselves???
    Jun 2012
    San Antonio
    Hello guys,
    I tried replacing the PCV on my 3.8 V6 2007 Grand Prix after a tune up and could not find the location of the PCV. Does anyone know where its located? Also, my high beams turn on by themselves, especially when I have the left turn signal switch on. The minute the switch automatically turns off as I straighten the steering wheel the high beams turn on. I usually tap the turn signal stick and they come off. Heck sometime the cars light turn off completely and I have to turn my high beams on so I can see. Any help would be appreciated. Thinking its the actual signal switch, but figured someone here knows best. Thanks!
  2. #2 Re: Where is the PCV location and why do my high beams turn on by themselves???
    St. Louis
    Sounds like the multifunction switch is shot.
    PCV is under the MAP at the pulley side of the engine.
  3. #3 Re: Where is the PCV location and why do my high beams turn on by themselves???
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    It's located on the passenger side between the alternator and coil pak,it will have a vaccum line to it, next to the map sensor. As for your lights, I know nothing about electrical systems, sorry.
  4. #4 Re: Where is the PCV location and why do my high beams turn on by themselves???
    Pennsylvania
    Be careful when you twist the MAP sensor off, the plastic clip on it is brittle, and if you grab it the wrong way you can snap that clip... trying to put it back in, too. Just be gentle. When you get the MAP off, the PCV will be right in that hole, just pull up on the little nipple sticking out. Make sure the O-ring stays in place unless you are replacing it, I dont think new ones come with an o-ring.
    Sport Edition Kv5 18x8
  5. #5 Re: Where is the PCV location and why do my high beams turn on by themselves???
    Jun 2012
    San Antonio
    Ohh cool! Thanks guys, that was quick. I will be ordering the turn signal switch from Amazon and replacing the PCV plug. Thanks again for all the help!
  1. High Beams
    By 2coolit in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2013, 11:07 AM
  2. high beams.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 03:44 PM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. fog lights with high beams?
    By RyanL in forum Visual/Body Modifications
    Last Post: 09-20-2011, 10:05 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
