Thread: How does the PCV work on Supercharged 3800 series II??
Results 1 to 5 of 5
  1. #1 How does the PCV work on Supercharged 3800 series II??
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    PCV is in the cap labeled "PCV" that is held down by two bolts on the top of the supercharger. My question is how does this function???
    Typically I am used to seeing a vented tube going from the valve covers to the intake track.
    Thanks in advance.
  2. #2 Re: How does the PCV work on Supercharged 3800 series II??
    May 2012
    Where winter never ends
    On my GTP it was a tube that ran from the back of S/C to the intake tubing.
    2000 Regal - Winter Beater
  3. #3 Re: How does the PCV work on Supercharged 3800 series II??
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Adecker View Post
    On the Series II it's just internally vented back into the manifold. On Series III it's externally vented into the intake. Works the same either way.
    7"
  4. #4 Re: How does the PCV work on Supercharged 3800 series II??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    To answer the origional question its just a one way valve between the crankcase and the intake. The valve is a replaceable piece that sits under that pcv cover and is held in place by a spring. It allows the crankcase to vent so that it doesn't pressurize and blow oil out of all of the seals. If I remember right the bottom of that hole is connected to the crankcase and near the top is a hole going to the intake. Valve sits between those.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  5. #5 Re: How does the PCV work on Supercharged 3800 series II??
    Mercer, Pa
    The PCV valve puts vacuum (from inlet of supercharger) to the crankcase. The crankcase now needs and air source (crankcase is sealed and vacuum is bad) so there is a hole in front of LIM. This hole let's air into crankcase. The passage connect through the supercharger up-through the throttle body (gen 3) and gets air from after the MAF and before the throttle plate. The air is measured by the MAF so the computer sees all air for combustion.
  1. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  2. Not a GP but a 3800 Series II none the less!
    By 3800Monte SS in forum Introductions/Noob Questions
    Last Post: 04-24-2013, 09:14 PM
  3. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  4. '97 3800 Series II n/a needs exhaust work. Suggestions?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2012, 04:10 PM
  5. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
