Thread: Comp G Axle ??
Results 1 to 17 of 17
  1. #1 Comp G Axle ??
    Jan 2014
    Kentucky
    I noticed a funny thuddind sound when taking left hand curves, I took off my passenger front wheel and noticed my inner CV joint on my axle had some slack in it like a bearing was out, so I pulled my axle and it had some wear on it the inner cv mainly. I am going to order a new axle and was wondering if the Comp Gs have a different axle than the GTPs I wouldn't think so but I really wanted to be sure before I order it..
  2. #2 Re: Comp G Axle ??
    They don't.
    Just the GT to GTP have different passenger side axles because of the diff.
  3. #3 Re: Comp G Axle ??
    Jan 2014
    Kentucky
    K Thanks...
  4. #4 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    FiveFinger.. got a question.. so not having an HD diff will the GTP passenger side axle work on a GT or will I have to switch over to an HD diff ?... OP sorry to thread jack lol
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  5. #5 Re: Comp G Axle ??
    Because the gearing is different from GT to GTP, (3.29's to 2.93) the HD diff makes the axle different.
    You would have to swap diffs if you wanted to use a GTP axle, but really there isnt a huge gain from swapping diff/ratio's.
  6. #6 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    What's different about the axle?
    .. and I thought what made the gearing different was the chain not the Diffs.. thought they were the same ratio for the GT and GTP just the later was stronger??
  7. #7 Re: Comp G Axle ??
    Arizona
    the diffs are also gear ratio specific. and FYI if there is a gear change you will also have to get re-tuned
  8. #8 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    Ohhh ok well damn i am an idiot lol i thought the only gear ratio change was from the chain.... and i know you have to re-tune for the Chain but i thought you could just drop in the HD diff and Axle?? or am i mistaken.. again lol
  9. #9 Re: Comp G Axle ??
    Someone can correct me if I am wrong, but the length the axle is different.
    And that all GT and GTP transmissions run the same exact chain. The diff will determine the final drive ratio that we refer to as 2.93 or 3.29. Because when you look at any tune, the number in the table is always 2.93 but the final drive ratio number is different.
  10. #10 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    ahhhh ok now it all makes sense lol.. guess i will be returning the pass axle to Orielys and getting the stock one haha.. no monies for the HD diff upgrade right now lol
    thanks for clearing all this up lol
  11. #11 Re: Comp G Axle ??
    Arizona
    The HD s diffrent not just because of the diff its also the diff cover which is longer which makes the axle shorter than a non hd
  12. #12 Re: Comp G Axle ??
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Ok guys im going to do a bit of clearing up here.
    First of all the difference between the 4t65ehd and 4t65e is ONLY the differential. The differentials are the exact same gear ratio but one is stronger. The stronger HD differential is a bit longer so you need a different differential cover and shorter axle (gtp axle in this case). You do not need to retune when switching differentials. You could even put a non HD differential into a GTP with no other changes other then the differential and axle.
    Gm did design different gear ratio differentials for the 4t65e but we did not see any in the grand prixs / wbody cars.... in fact I believe they didn't use anything but the one size in the usa market.
    The final drive changes on our cars at least are always done by changing the drive chain. Thats why when tuning these cars you actually don't tune in a gear ratio you enter in your chain / sprocket ratio. For a non supercharged car the ratio is 1.00.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  13. #13 Re: Comp G Axle ??
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    I think the only time we had a stock 3.29 gear ratio was the 97 GT's with the 4t60e trans.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  14. #14 Re: Comp G Axle ??
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Quote Originally Posted by MCbatt View Post
    and 04-05 Comp Gs...
  15. #15 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    See I could have swore I remembered reading that the Diffs dont determin the final gear ratio..and they are the same ratios for the GT and the GTP.. it's all in the chain for the final drive ratio
  16. #16 Re: Comp G Axle ??
    Dec 2010
    ATL,Georgia
    I found the info I read a long time ago about the differences between the diffs.. from Thrasher
    http://www.thrashercharged.com/tech_htm/FAQ-4t65E.shtm
  17. #17 Re: Comp G Axle ??
    hangover park IL
    some 03+ tranny's have a FDR altering diff...previous to that its just the "straight ratio" diffs that do not change FDR
    the 04+ ULEV L26 GP's have a diff that turns the 3.29 fdr chain equipped tranny's into a 3.05...the taller gear than a standard 3.29 NA trans is what helped GM get the ULEV certification
    throw that diff into a 2.93 chain trans and youll get 2.84 iirc
    I know I did the calcs for the 1/2 mile event with the hd/non hd "same ratio" diffs maxing us at 165 in 3rd at 7k where the 3.05 would let us take 3rd gear to 17x at 7k
    mostly a pie in the sky math exercise its a viable option since we only have a 3.29 FDR GMR chain...
    the 4t80e is the trans with all FDR adjustments via the output/differential planetary gears, yer a 1hr diff swap away from 3.11, 3.48, 3.71 fdr's
    ~James~ Psychotic Gearhead
  1. c.v. axle
    By djrepoman in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2013, 05:17 PM
  2. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  3. axle nut
    By Solo GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2011, 11:56 AM
  4. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
