Thread: 91 caprice flooding out after running 5 min
Results 1 to 20 of 28
  1. #1 91 caprice flooding out after running 5 min
    I just bought a 91 caprice and haven't been able to get it home yet since it'll only run for about 5-10 min before flooding out. I replaced the spark plugs and coolant temp sensor and it didn't fix anything. I'm just wondering if anyone else has any ideas. It has a 5.0 in it tbi.
  2. #2 Re: 91 caprice flooding out after running 5 min
    TPS, Vac Leak.
    Seems to be the common things on forums.
  3. #3 Re: 91 caprice flooding out after running 5 min
    St. Louis
    Any vac leaks? Being that old those old lines are bound to be brittle by now. Also, check the base of the throttle body as they like to leak there, and of course could also be a stuck injector.
    How does it idle?
  4. #4 Re: 91 caprice flooding out after running 5 min
    I'm thinking maybe coil going bad or map sensor?
  5. #5 Re: 91 caprice flooding out after running 5 min
    The Boss Iceman6669's Avatar
    Jun 2011
    Prolly not MAP sensor... I had that unplugged on my silverado for a while and it ran fine.
    2011 F-150 Yote powered
  6. #6 Re: 91 caprice flooding out after running 5 min
    no vacuum leaks. It idles like a dream
  7. #7 Re: 91 caprice flooding out after running 5 min
    Mar 2012
    NC
    Watch the injector spray pattern. Those injectors gum up over time and cause some fun running issues...like when the PCM tries to increase pulse width the injector starts dribbling. Also, after about 5 minutes of running, the O2 starts reporting so you might have an O2 pegged lean causing it to try to add fuel.
  8. #8 Re: 91 caprice flooding out after running 5 min
    So I'll try checking the spray pattern out and then unplugging the o2 and seeing about that as well. I like the cheap suggestions lol. I only paid $250 for the car so I'm trying to flip it.
  9. #9 Re: 91 caprice flooding out after running 5 min
    Mar 2012
    NC
    Well, that shouldn't be hard with all the people buying those things and "drinking" them. SMFH
  10. #10 Re: 91 caprice flooding out after running 5 min
    I have a black guy interested and I told him $1000
  11. #11 Re: 91 caprice flooding out after running 5 min
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    you should keep it and throw on some 32's
    2012 F150 STX
    - Gonna be a race truck
  12. #12 Re: 91 caprice flooding out after running 5 min
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Screw 32's, get a lift kit:
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  13. #13 Re: 91 caprice flooding out after running 5 min
    Mar 2012
    NC
    They sell for that dead down here. lol
  14. #14 Re: 91 caprice flooding out after running 5 min
    If i kept it it would be laying frame on 18's
  15. #15 Re: 91 caprice flooding out after running 5 min
    Around here you could get $4-5k+ with it running and that's all. Guys buy those old caprice up like hot cakes here.
    04 Comp G.
  16. #16 Re: 91 caprice flooding out after running 5 min
    I'll drive it down then lol
  17. #17 Re: 91 caprice flooding out after running 5 min
    Mar 2012
    NC
    First it has to run...without flooding out. LOL
  18. #18 Re: 91 caprice flooding out after running 5 min
    The more I think about it the more I'm leaving toward o2. Makes sense
  19. #19 Re: 91 caprice flooding out after running 5 min
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    I always wanted a newer one with a lt1. I thought it would be fun to make a wagon fast. People are always shocked how fast my regal is. Would be just as fun beating mustangs in a big wagon. As far as your problem go's it wouldn't be your tb gasket, they idle up when they go bad. Same with a vac leak, unless its a big one. A bad map, will make it sound like it has a cam. So will the egr they stick, could idle up to. Inside the tbi at the bottom of the injectors there's a gasket that will leak, but would cause it run rich all the time. Same go's with the top gasket, where the pressure regulator is in. If you had a stuck open injector, chances are it wouldn't start. Since they run rich, during start up. You said you replaced the coolant temp sensor, that would have been my first guess. Did you look at the wire that go's into it? I would also take the tps out there plastic, on the pass side tb. They go bad. The groove from the tb pin becomes loose over time. If you check all of this including the o2, i would then look at the computer pins. Pull the harness off the computer and look for corrosion. I have seen distributors go bad with the plastic gear at the bottom has slop. When the computer go's to adjust the timing, they will run rough and rich. Same with the pickup module they will go bad from poor grounding.
    Sent from my LG-L38C using Tapatalk 2
  20. #20 Re: 91 caprice flooding out after running 5 min
    Well today I ran it across town and it ran great the whole time left it set for about 4 hours hopped in it to run to dollar general and it ran like **** the whole time except at idle. So I'm thinking tps maybe.
  1. 1967 Chevrolet Caprice
    By SgtMarshal in forum Off Topic Discussion
    Last Post: 01-21-2014, 08:44 AM
  2. 98 gtp gt flooding
    By IN2DeeP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2012, 10:31 AM
  3. caprice
    By ryanmjw in forum Off Topic Discussion
    Last Post: 08-29-2011, 04:09 PM
  4. Engine Flooding.
    By iroc34 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-05-2011, 01:49 AM
  5. 2011 Caprice
    By pontiac88 in forum Off Topic Discussion
    Last Post: 11-16-2009, 08:21 PM
