Thread: My engine tapping noise with Video
Results 1 to 17 of 17
  1. #1 My engine tapping noise with Video
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    Heres the tapping noise im getting every cold startup. Goes on for about 3 minutes. This vid was taken right after i started the car after it sat for the night so its revving high. you can still here the tapping though. what do you guys think this is??
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    Do any of those 2 links work for you guys? I'm trying to do this on my girlfriends Macintrash.
  3. #3 Re: My engine tapping noise with Video
    Charles City, IA
    The links to the site work, but the video would not load for me. The ticking sound you are getting could be the rockers/lifters making some noise from the oil not fully reaching them until the engine is warmed up.
    SMGPFC Two Nipple General
  4. #4 Re: My engine tapping noise with Video
    Oklahoma
    I couldnt get the video to load either.
  5. #5 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    ahhh, I have failed. Not sure whats going on. Can I email one of you guys this vid so you can post it up for me?
  6. #6 Re: My engine tapping noise with Video
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ya video would not load.
    if it goes away after car has been running for a few. Most of the time points to a lifter not getting primed ( oil not getting to it )
    Syn might want to help me with this. But i had this happen on my first gp and i added a can of sea foam to oil changed my oil but subed a qt with lucas oil stabilizer. After a couple driving cycles it went away.
    What kind of oil /filter your are you using. A bad oil filter can hinder correct oil pressure (syn?)
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  7. #7 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    im using amsoil 5w-30 and an amsoil filter. It started happening right after I switched to synthetic. Can I send you this vid so you can have a shot at uploading it? its a windows media player file i dont know what its not uploading for me...
  8. #8 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    my car also did this when using a wix filter.
  9. #9 Re: My engine tapping noise with Video
    Oklahoma
    You are correct, I have run across countless numbers of vehicles in which the oil filter caused an issue with oil flow. Ive seen it more with fram filters than anything, but there have been others.
  10. #10 Re: My engine tapping noise with Video
    Oklahoma
    Well I run Amsoil motor oil and an Amsoil oil filter with a by-pass filter system and Ive not had that issue. Im not a huge fan of Seafoam, I much prefer to use Auto-RX which will do an excellent job of cleaning out junk in the engine if that is the cause of any lifter pump up issues.
    I dont know where else to host your video other than maybe try setting up an account on Photobucket and upload it there and link to it. Putfile has always seemed a hit or miss proposition to me in my experience with it.
  11. #11 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    Got it on!
  12. #12 Re: My engine tapping noise with Video
    Oklahoma
    That doesnt sound at all like lifter noise. Its too inconsistent. Lifter noise is usually very consistent, steady and sometimes will go away as the engine warms up and the oil thins out some.
    That sounded more like, to me anyway, like something vibration, like something was loose and shaking around
  13. #13 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    hmm, I think sunday I'm going to have to cold start it and get under there and see if I can find/see something. It sounds like its coming from the bottom driver side.
  14. #14 Re: My engine tapping noise with Video
    Oklahoma
    Bottom drivers side huh? The only think on that side Ive known to rattle is the flex plate, but that didnt sound like that either, at least not like any I have heard.
  15. #15 Re: My engine tapping noise with Video
    Feb 2008
    South Bend, IN
    Thanks for the help. I'm getting my plog installed very soon so i'll have my friend check it out when its up on the lift and see if we can spot anything.
  16. #16 Re: My engine tapping noise with Video
    Charles City, IA
    Yeah x2 on something being loose. It doesn't make since that it goes away after the car warms up tho.
  17. #17 Re: My engine tapping noise with Video
    Tulsa, Ok
    Ok now that the vid is up that is not lifter tick.
    Sounds like a lose flex plate.
    Other causes that make that sound:
    -Piston slap
    -bearings
    I would check flex plate first.
    Under car there is a plastic shield on tranny between starter and tranny. Take that off you now have access to flex plate. Make sure there are no lose bolts. May have to have some one quickly crankt he car so you can get to allt he bolts or take plugs out and should make it easy to turn engine with flex plate since there is no pressure in engine.
    98' GS - Sold
  1. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  2. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
  3. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
  4. SC "tapping" noise... HELP!!
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2008, 05:30 PM
  5. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
