Thread: Ghetto premium for people in E85 areas.
Results 1 to 20 of 28
  1. #1 Ghetto premium for people in E85 areas.
    Feb 2009
    flintnasty MI
    I found that recently 93 octane has been getting up there in price (uncommon to see the 20 cent markup anymore), and I am soon switching to E85 in my DD stock GTP (with 3.2 pulley) so I have been experimenting with different E85 blends in the mean time.
    After much experimentation, and a bit of math, i was able to run e30 (there is a pick-a-mix e85 station in greenville) without causing any gruff to the stock fuel system, and I run very easily with zero KR ever in the cold even... Fuel trims that are normally a few positive are now about +14.
    Next time you are at the gas station with E85 fill up 3/4 tank with 87 and pile in e85 on top. A 25% to 40% e85 mix will run just fine in a stock GTP, or a modded one with room in the injectors. If you see a check engine light it means you will be running slightly leaner than 14.7 at cruise, and a little lean at WOT, which on my stock car did not cause any problems.... I expect even a edge tuned car to have no issues either.
    I also plan on doing this in my TBSS during the summer.
  2. #2 Re: Ghetto premium for people in E85 areas.
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Tagged for results. Hope this works out, filled up earlier for $4.09/gal for 93.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  3. #3 Re: Ghetto premium for people in E85 areas.
    Huh. Too bad we only have like 2 stations here with E85 :/
  4. #4 Re: Ghetto premium for people in E85 areas.
    Feb 2009
    flintnasty MI
    Quote Originally Posted by WhiteLightningGTP View Post
    It works, ive put many a tank through of E30. Octane is probably between 93 and 95 according to math.
  5. #5 Re: Ghetto premium for people in E85 areas.
    Arizona
    You should also include that its still e70 right now...winter blend once e85 comes back out in the summer you'll have to adjust your ratio
  6. #6 Re: Ghetto premium for people in E85 areas.
    Feb 2009
    flintnasty MI
    The science isnt that specific. In the winter you know you can run a bit extra and the summer a bit less but I wouldn't think about it.
  7. #7 Re: Ghetto premium for people in E85 areas.
    I'll give this a try sometime though.
    Sent from A Galaxy Far Far Away........
  8. #8 Re: Ghetto premium for people in E85 areas.
    Ghetto premium sounds cool.
  9. #9 Re: Ghetto premium for people in E85 areas.
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    This will probably cost you more money then just using the correct fuel due to the lower energy content of E85.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  10. #10 Re: Ghetto premium for people in E85 areas.
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Those who have e85 close at hand be thankfull... wish I did
    Your gas prices aint bad either...paying $5.50/gallon for E10 93/94 octane here...
  11. #11 Re: Ghetto premium for people in E85 areas.
    Dec 2012
    Where 4T65E's were born
    If you're questioning the ethanol rating you can always test it, all you need is a 10ml graduated cylinder and water. I bought one just because.
    Sold.
  12. #12 Re: Ghetto premium for people in E85 areas.
    Feb 2009
    flintnasty MI
    Quote Originally Posted by RivMan View Post
    -Rob
    Tested that enough to the point that I cant notice it. Its such a low concentration, and I never get the calculated "25% loss of mpg" I should get with pure e85.. its usually closer to 15%.
    I'm sure it is slightly less, but over here I am paying roughly 6 bucks less for 14 gallons of ghetto premium over regular premium... so it goes quite far.
  13. #13 Re: Ghetto premium for people in E85 areas.
    Oct 2012
    Pinckney, MI
    $54.46 (14gal @3.89/gallon) = 322 miles @ 23mpg = $0.169 / mile
    $48.46 = 273 miles @ 19.55mpg (15% less) = $0.177 / mile
    Ghetto premium costs more per mile then regular premium even at a 15% penalty.
    -Rob
  14. #14 Re: Ghetto premium for people in E85 areas.
    Feb 2009
    flintnasty MI
    its not 15% less even with the most extreme interpretation of the math... its at an absolute max 8% less, and reality points to 4% being right....
    $47.46 (14gal @3.39/gallon) = 306 miles @ 21.85mpg (5% worse) = $0.155 / mile
    Its an average of $5 a tank savings for me assuming a 5% loss in range, and $7 without the range loss.
  15. #15 Re: Ghetto premium for people in E85 areas.
    May 2014
    terre haute, Indiana
    alright so now that i saw that itll work on a gtp what about a gxp? JW
  16. #16 Re: Ghetto premium for people in E85 areas.
    Why wouldn't it work for a gxp?
  17. #17 Re: Ghetto premium for people in E85 areas.
    Nov 2011
    NY
    You can save even more $$$ if you make your own ethanol... Lots of work though, just sayin!
    Bulk corn syrup, 55 gal drum, some yeast and heat... Whoola! Ethanol!
    (google search for easy instructions)
  18. #18 Re: Ghetto premium for people in E85 areas.
    Even in DC E85 is currently almost a dollar cheaper per gallon vs pump............
    E85 is worth every penny and the hassle of only having one station in all of the DC area!
    Go ahead and ask jayroca what he thinks about it............
  19. #19 Re: Ghetto premium for people in E85 areas.
    Nov 2011
    NY
    After my cam build is up and running solid, ima try that E85!
  20. #20 Re: Ghetto premium for people in E85 areas.
    Yeah once I get my cam in I'm gonna run on corn.
  1. Replies: 3
    Last Post: 03-02-2014, 08:17 PM
  2. Replies: 11
    Last Post: 01-09-2014, 01:49 PM
  3. Ghetto Blasta.
    By 92GhettoBlasta in forum Members Rides
    Last Post: 01-23-2012, 12:56 AM
  4. Is there a cleaner way to do this? (ghetto rig)
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-10-2011, 12:08 AM
  5. Ghetto Home theater :)
    By Toofastgs in forum Off Topic Discussion
    Last Post: 09-24-2008, 08:42 PM
