I have a 2004 grand prix gtp comp g with 101k miles. Car runs totally fine until you get to 70 to 80mph then it starts hesitating and seems clogging to change gear. I took it to a shop and i test drove it and showed him so i accelerated hard and the check engine light started flashing. We t back to the shop and mechanic ended up checking engine everything looked fine then checked transmission fluid and it was dark and smelled. So diagnostic answer was lets do a filter and replace fluid and then from then will determine if rebuild needed. Should i get a second opinion I'm thinking of selling thats why i ask. Plugs and wires were changed 10k miles ago. Mechanic said it had bcm codes and no other codes. Could it be the transmission it changes gears great before highway speeds
