Thread: Drag radials or street tires for daily use?
Results 1 to 5 of 5
  1. #1 Drag radials or street tires for daily use?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I bought a set of new hankook ventus v2 street tires for the Trans Am a few months back, they handle relatively good if I drive it normally but they also spin very easily if not careful. The thing is that I haven't driven the car that much in the past few months maybe 3000 miles max and I already went through half the tire's life on the rear. I was avoiding drag radials because I feared they would wear out too quick but given the current circumstances I'm thinking that the wear may not be that bad with the drag radials not to mention the additional grip.
    I don't normally do burnouts, donuts or bring up the tires up in smoke and I only took the car to the track with the current tire set 4 times and did just a couple of passes on each occasion. What do you guys think would the drag radials last at least the same as the current set or still less?
  2. #2 Re: Drag radials or street tires for daily use?
    chances are they are a very soft tire, soft tire means they wear faster. harder tire last longer but sucks in any thing other then dry conditions.
    i bet if you did a nice little burn out, then did a launch right after they grip like mad.
    back in the day a friend had a 70 roadrunner with Micky Thompson drag radials, they spun like butter, but after that first burn out they were nothing but grip. they also wore out rather fast under rather normal driving. very soft tire.
  3. #3 Re: Drag radials or street tires for daily use?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    ^^ Pretty much nailed it.
    If you ever drive in rain, don't go DR. They are sketchy in the rain.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Drag radials or street tires for daily use?
    Mexico
    We have like 6 months of rain every year in this region hehe, no snow though.
  5. #5 Re: Drag radials or street tires for daily use?
    its just that with every turn of the tire, it wears off.
    its a good tire to take out for drag night and such, put them on at home drive to the track. other then for racing there not so good for much else.
  1. Drag radials
    By baker428 in forum Tires & Wheels
    Last Post: 07-02-2013, 09:53 PM
  2. Looking to run some drag radials
    By Sushamouf in forum Tires & Wheels
    Last Post: 03-28-2013, 09:36 PM
  3. Street Drag Tires
    By RayGTP in forum Tires & Wheels
    Last Post: 04-09-2011, 10:47 AM
  4. Drag Radials
    By PontiacGTPSE in forum Off Topic Discussion
    Last Post: 10-14-2009, 10:57 AM
