Thread: AEM air/fuel gauge question
Results 1 to 20 of 25
  1. #1 AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    Greetings!
    I got the gauge wired and the sensor installed but have a problem. The gauge is showing 3 dashes and the outer ring lights peg when I plug in the sensor.
    I can't find a THING online about the reason.......HELP! "please"
  2. #2 Re: AEM air/fuel gauge question
    Are you running really lean?
  3. #3 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    I wish I knew......Sure does smell lean
  4. #4 Re: AEM air/fuel gauge question
    It'll show just dashes if you are really lean. When my pcv was unhooked mine showed just dashes
  5. #5 Re: AEM air/fuel gauge question
    Florida
    Try patting the gas a little at idle, just enough to get it to rev a tiny and drop off suddenly, You should be able to get it to swing into the readable AFR, if so, you are crazy lean.
  6. #6 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    Tried it...still have dashes. Should it have the dashes even when it's not plugged into the down pipe? I may have a wiring problem, but, I doubt it.
  7. #7 Re: AEM air/fuel gauge question
    It's not plugged in? That's your problem.
  8. #8 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    Bwaaaaaaaaaaa! Good one!
  9. #9 Re: AEM air/fuel gauge question
    So it is plugged in?
  10. #10 Re: AEM air/fuel gauge question
    Florida
    if it has no data from the sensor it will stay dead on 14.7 the entire time (IE unplugged)
    Just dashes means lean as **** or rich as ****.
    Does it give you 2-3 letter/number combinations when the gauge turns on?
  11. #11 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    The harness is plugged in to the sensor. Dashes is all I get. Mount the sensor in the downpipe, start car, dashes is all I get.
    So, the gauge must be getting data. The car smells really lean, but, I have no idea how to check or change that.
    Wouldn't the plugs be turning black in a really lean condition?
  12. #12 Re: AEM air/fuel gauge question
  13. #13 Re: AEM air/fuel gauge question
    What do you have done to your car and what are you driving?
  14. #14 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    It's all in my signature as far as I know .
  15. #15 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    Yes it does.
  16. #16 Re: AEM air/fuel gauge question
    Florida
    Quote Originally Posted by traildog View Post
    Yes it does.
    Well that means the gauge is working fine then. There's a chance the sensor is possibly bad, or it's tuned super lean.
  17. #17 Re: AEM air/fuel gauge question
    some how you lost your siggy.
  18. #18 Re: AEM air/fuel gauge question
    It's in your sig in the top but not the rest of them. What tune do you have?
    "Halfassery" 2000 GTP, L67 Engine and Tranny,ZZP 3" down pipe, Triple Gauge A-Pillar Pod, 10.5 mm Plug wires, polly dogbone bushings, polly engine mounts, modded fuel rail, #80 injectors, manual boost controller, front plog, turbo crossover and oil feed and return system.TaiL wastgate and BOV.6262 Billet Wheel Turbo and other stuff..........
  19. #19 Re: AEM air/fuel gauge question
    Banned
    Dec 2013
    Indiana
    I have NO idea................
  20. #20 Re: AEM air/fuel gauge question
    If you get zero change in the "dashes" when you blip the throttle, the sensor is likely dead.
  1. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  2. autometer lowband Air/fuel gauge question
    By 99GPGTP in forum General Tech Discussion
    Last Post: 07-12-2011, 07:07 AM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. fuel gauge help!!
    By momo29 in forum General Tech Discussion
    Last Post: 03-05-2009, 08:11 PM
