Thread: Brake Discs
Results 1 to 4 of 4
  1. #1 Brake Discs
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Has anyone seen the ceramic brake disc? What is ordinarily the steel rotor is a ceramic brake disc with the hub built in. Caught a glimpse of it on tv last night.
  2. #2 Re: Brake Discs
    St. Louis
    The carbon ceramic ones? When you saw it on tv, what car was it on? I ask because these are usually made for exotics only. I know Brembo makes some.
  3. #3 Re: Brake Discs
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    Cool, my sons kart has a ceramic rotor i thought that was cool :-)
    Sent from my LG-L38C using Tapatalk 2
  4. #4 Re: Brake Discs
    Dec 2010
    ATL,Georgia
    Quote Originally Posted by FordMan77 View Post
    ^This... hes right they are expensive as hell so only the exotics and high-end cars are equipped with them. Also under normal driving they are useless, they have a very high-heat optimal operation so that means unless your tracking the car you will prob never use them to their full potential( also the breaking will be lacking under normal driving due to this as well)
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  1. Hot brake discs
    By whitehead in forum Brakes/Suspension/Chassis
    Last Post: 05-31-2011, 02:07 AM
  2. Brake discs - a good cheap set?
    By Deezul_AwT in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2010, 03:20 PM
