Thread: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    ok i may have over looked a thread somewhere on this but im in need of some information on what the best way of going about this is. the car is a 2005 base model plain jane grand prix 3800 series III. its my buddies car and hes pushing 170k on it and he just paid it off so hes wanting to rebuild the motor or buy a motor out of a gtp and swap it in there or just swap the top ends out can that be done. pretty much whats the best way to go about doing this, price wise parts wise and labor wise? also he found a series II motor i believe out of a 99 gtp with the trans and everything and he wants to know if he picks it up if its even possible to drop that in his car? pretty much im at a loss i have no expirence with doing this nor does he and we need help. thanks guys
    -brad
    THE RIDES OF 2014​ 98' dodge ram 1500 sport/raminator-DD
    97' ford f-150 xlt-mud toy
    97' monte carlo z-34-project never to be done
    05' grand prix gxp-weekend warrior
  2. #2 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Florida
    Not really worth the hassle to try and swap an L67 into it. You'd have to get some 04+ returnless Supercharged fuel rails (or aftermarket) and a TB adapter to run the gen 3 SC with the drive by wire TB on his car.
    Easiest route would be to just swap a whole L32 (supercharged Series III) motor in. Then keep his L26 (N/A Series III) and keep it as a spare, sell it, or build that one up as time/funds permit.
    Next easiest would be to topswap with a L32 top end. About as involved as a whole motor swap (having to strip it to a short block and rebuild it back up) and would be much simpler than trying to put the L67 in there.
  3. #3 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    im assuming the u have to have the correct trans for a l32 swap? as the stock on on his car wont work?
  4. #4 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Dec 2012
    troll land
    You can tune ite for the stock trans, mebbe use a comp g bin
  5. #5 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Florida
    You should be able to use the L26 trans with an L32 no problem.
  6. #6 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Mercer, Pa
    You can topswap you just have to use l32 rails and gen 5 supercharger. You can use L67 or L32 heads.
    You don't need a complete block and L32 blocks can be quite expensive. Last I looked Morad wanted $800 for one with 170,000 miles plus shipping.
  7. #7 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    with out moding it/ tuning it? ive been told before that all the trans are different in all gp the switches/ shift points will throw off the computer and it wont run right?
  8. #8 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    Quote Originally Posted by sseilmnop View Post
    hes prepared to spend a bit of money lol he was ready to pay 800 for one with 194k on it, glad he didnt though. but taxes are right around the corner
  9. #9 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Feb 2009
    flintnasty MI
    cheap turbo kit would be way easier and cheaper.
  10. #10 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    me nor he know nothing about turbos
  11. #11 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Quote Originally Posted by LSFoFaSho View Post
    The stock trans is fine. Im running a non HD trans in my 2.55 setup with no issues... yet.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  12. #12 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I drive a swapped 04 Base Model GT, so I've got a little insight here.
    Engine: Top swap or L32 swap, don't bother with an L67. I'm running an 04 GTP L32.
    Wiring / PCM: It's possible to run with the wiring from your L26, but I don't recommend it. Swap out the engine harness with one from a GTP, and run a GTP base PCM calibration. Depending on your Transmission, you will HAVE to change the PCM programming to match the gears in the trans. This will also require swapping out your ABS module with one from a GTP for TCS to work properly, but that's real easy and pretty cheap. That's the setup I'm running. (Note, a CompG harness / PCM / ABS Module will NOT work without more changes.)
    Transmission: You can run any trans with some work.
    L26 Trans: 3.05 Gears, non HD Diff, but no other changes required to the car.
    L32 Trans: 2.96 Gears, HD Diff, Need new CV Shaft on the passenger side.
    L32 CompG Trans: 3.29 Gears, HD Diff, Beefyer first gear Band, a few other upgrades... Need new CV Shaft on the passenger side, Need to replace with Channel Plate / Valve Body / 4th Gear Clutch with GTP parts - This is what I'm running.
    As for a donor, find a Running but Wrecked GTP or CompG and have all the parts you need, plus lots of spares. That's the route I went.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  13. #13 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    Quote Originally Posted by RivMan View Post
    -Rob
    thanks for the insight this is the kinda help i was hoping for i knew there had to be someone on here who had done this already, and whats a comp g? im still a noob lol
  14. #14 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    SE Level Member FASGP's Avatar
    Toronto ON
    The Comp G is the step up to the top end above the GTP of these years. They had a few more bells and whistles, including the trans gearing for example...
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  15. #15 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Jan 2014
    United States
    Quote Originally Posted by FASGP View Post
    so it was a gtp? or it was just a super charged gt? how can u tell the difference ive never seen a comp g badge or anything
  16. #16 need info and input on doing a swap on a series 3 05 grand prix to a supercha...
    It's a GTP if it has the comp g package
    It'll be either a 04-05 if it's a comp g
    -red calipers
    -tab shift
    -some 05 have comp g badges on the doors
    That's just a few basics
    04 Comp G.
  17. #17 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    3.05 gears on L26?
    Sent from my SPH-L720 using Tapatalk
  18. #18 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Toronto ON
    The GT with L32 supercharged started in 06. Before that there were no GT's with L32, only GTP and Comp G. GP's with onstar antenna at front of roof are pre 2005, and at rear are post 2005. Comp G also had tapshift inside on steering wheel.
    3.05 gears on L26?
    Yes, GT trans with L26 was 3.05 ratio.
  19. #19 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    Sep 2012
    North Carolina
    And the post 2005 base models were 3.29 right?
  20. #20 Re: need info and input on doing a swap on a series 3 05 grand prix to a supercharged
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    I hate to disagree, but a topswap is much easier than an entire motor swap, and as zero reliability issues. Me and frosty95 are both running awesome topswap setups on stock trans.
    04 GTP -HAI, 1.9 rockers.
  1. supercharged motor swap 04 impala to 04 grand prix
    By alreadytooken in forum Engine
    Last Post: 05-12-2013, 10:49 PM
  2. Replies: 2
    Last Post: 09-28-2012, 01:19 PM
  3. 07 prix gt pcm swap. Need info
    By szalajka05 in forum General Tech Discussion
    Last Post: 04-01-2012, 04:04 AM
  4. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  5. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
