Thread: My plugs are gapped at .045
Results 1 to 20 of 32
  1. #1 My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    Seems wrong to me and I've been scanning the forum and finding all kinds of answers.....Autolite 103's what should the gap be?
  2. #2 Re: My plugs are gapped at .045
    as big as possible until you start blowing them out because of boost.
    stock is .060", but i always ran .045" because i was lazy and i was running smaller pulleys (3.2).
    however, since you're turbo .045" seems right...unless you're running a lot of boost, then .040" or .035" seem more appropriate. it's all trial and error.
  3. #3 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    As i get all of them pulled, I'm finding them from .050 to .039. I have one plug to go. Scottydogs told me to remove the dog bone bolts to pull the engine forward so I can get to the last one. I want to do a compression test while I have them out. Can I do it without disconnecting anything else?
  4. #4 Re: My plugs are gapped at .045
    leave all the plugs out, then screw the tester in each plug hole, crank the engine over. it wont start because its got no plugs installed. and will spin faster with no plugs as well.
  5. #5 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    [QUOTE=Scottydoggs;1181729]leave all the plugs out, then screw the tester in each plug hole, crank the engine over. it wont start because its got no plugs installed. and will spin faster with no plugs as well.[/QUOT
    I can't get the last plug out.....
  6. #6 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    the disconnected o2 sensor is in the way and I can't get it out either.....
  7. #7 Re: My plugs are gapped at .045
    what one? and why? i can get my gorilla hands back there with the engine rocked forward. and you should have a plog back there, not much to be in your way.
  8. #8 Re: My plugs are gapped at .045
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    You can do it...
    And after you do gap them plugs at 0.035
  9. #9 Re: My plugs are gapped at .045
    Quote Originally Posted by traildog View Post
    if your plug socket has a bolt head on the top of it, try sliding the socket on, then use a wrench to break it free. or a swivel may help.
  10. #10 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    dam local parts store only has 606 plugs. Wrong ones, right?
  11. #11 Re: My plugs are gapped at .045
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    ya just go to another store and get 103s. 606 plugs are 3 heat ranges to hot
  12. #12 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    did ya ever have a tool in the box you didn't think you were ever gonna use? Dam weedeater spark plug wrench came in REAL handy tonight...I got it out!
  13. #13 Re: My plugs are gapped at .045
    yup, sometimes the odd tool gets it done.
  14. #14 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    Back with the plugs...checking compression now
  15. #15 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    Front right 160 center 150 left 152
    Back left 156 center 160 right 155
  16. #16 Re: My plugs are gapped at .045
    if your looking at the engine from the bumper the pistons are.
    2 4 6
    1 3 5
  17. #17 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    looks ok to me eh?
  18. #18 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    2 4 6
    1 3 5
    I was gonna ask you for that again! I lost my copy. Thanks.
  19. #19 Re: My plugs are gapped at .045
    not to bad, at least they are all close. you dump some oil in each cylinder do it again, its should up the compression a bunch. theres a dry and wet testing.
  20. #20 Re: My plugs are gapped at .045
    Banned
    Dec 2013
    Indiana
    Wet test ain't happening tonight....I'm bleeding profusely form both hands.....JK...but they hurt.....
  1. which plugs?
    By Senshi09 in forum General Grand Prix Discussion
    Last Post: 01-25-2013, 07:40 AM
  2. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. Side gapped 103's
    By TDCRacing in forum General Tech Discussion
    Last Post: 10-05-2008, 09:00 PM
  5. I did it. Side gapped the plugs
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 04:46 AM
