Thread: cylinder 5 misfire
Results 1 to 5 of 5
  1. #1 cylinder 5 misfire
    Jul 2013
    adrian, mi
    ok so the other day i drove to the store no problems when i left i had misfire cylinder 5. i checked the coil packs all 3 are at 5.5k ohms at the male ends. i switched the 5-3 and 6-2 coil packs to see if cylinder 3 would misfire. i drove the car this morning and every thing was good for about 25 minutes until cylinder 5 started miss fired again. i pulled the plug and theres fuel on it so the injector is working. could this be a bad control module? 98 gtp very few minor mods. 3.4 pulley zzp 1.0 3 dp 104's ported front mani. help please
  2. #2 Re: cylinder 5 misfire
    St. Louis
    Could be, or maybe a bad plug wire.
  3. #3 Re: cylinder 5 misfire
    Jul 2013
    adrian, mi
    just replaced plugs and wires 3000mi ago
  4. #4 Re: cylinder 5 misfire
    Florida
    Swap the plug from #5 with #3 and see if it follows. If not, then swap the wire from #5 with #3 and see if it follows.
    Most people dont realize that spark plugs can short to ground on the head and cause a misfire if the porcelain is cracked. (I had 2 AL104s do this within 1000miles)
    Start simple and then work your way up to the more complex things. It could be a bad ICM, but usually you'll end up with a multiple misfire that seems random.
  5. #5 Re: cylinder 5 misfire
    Willoughby, Ohio
    agreed, hope is a loose connection or bad plug, something easy
  1. Misfire on cylinder 3 and 4
    By bhuyser in forum General Tech Discussion
    Last Post: 09-08-2011, 11:17 AM
  2. cylinder one misfire
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2010, 03:48 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
