Thread: 2004 gtp swap everything into 99 gt
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: 2004 gtp swap everything into 99 gt
    Quote Originally Posted by l67ss View Post
    Ive heard the newer style injectors are better anyway
    if his 99 harness would only just plug into them.
  2. #22 Re: 2004 gtp swap everything into 99 gt
    that's easy soldier the right ends on.......
  3. #23 Re: 2004 gtp swap everything into 99 gt
    why make work tho?
  4. #24 Re: 2004 gtp swap everything into 99 gt
    hangover park IL
    well as a cheapskate...i wood
    ~James~ Psychotic Gearhead
  5. #25 Re: 2004 gtp swap everything into 99 gt
    Quote Originally Posted by Turbocharged400sbc View Post
    well he could use the l32 injectors in a pinch...just swap connectors
    Yeah but not the rail
  6. #26 Re: 2004 gtp swap everything into 99 gt
    Nov 2012
    pistolvania
    i'm with this guy full time job is distribution warehouse so i want to keep the cost down as much as possible lol
  7. #27 Re: 2004 gtp swap everything into 99 gt
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I dont know why everyone is making this sound so diffacult. Swap only the engine over, Then swap the fuel rails, Use an adaptor plate so you can run your gt throttlebody. All of the connectors should plug right in. You will be missing the connector for the boost bypass valve but it is useless anyways (I havent had mine since... ever). You will most likely need to use injector adaptors (ev1 to ev6 from racetronics?) or upgrade to 60#s with ev1 connectors. Then have someone come over to flash the pcm. Best bet is a 2001 or 2002 gtp bin file and then use your stock trans settings and maf table and the ve table from the 04 gtp and possibly the timing table as well.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  8. #28 Re: 2004 gtp swap everything into 99 gt
    Dec 2012
    troll land
    Think he needs to use an l67 fuel rail?
  9. #29 Re: 2004 gtp swap everything into 99 gt
    Nov 2012
    pistolvania
    just out of curiosity is there a walkthrough for this 04+ engine tranny swap to 97-03 i can reference while i try to undertake this
  10. #30 Re: 2004 gtp swap everything into 99 gt
    like a engine pull how to? why yest there a few here, if thats what you mean. how to pull just a engine, just a tranny, or both at the same time, out the top or bottom.
  11. #31 Re: 2004 gtp swap everything into 99 gt
    Quote Originally Posted by frosty View Post
    I told him to swap the Motor only
  12. #32 Re: 2004 gtp swap everything into 99 gt
    Nov 2012
    pistolvania
    not pulling that would be the easier part of the swap .. getting the engine and tranny in my 99 gt and having it start up and run with no hiccups ... i would run with the engine only if it were not for the fact that i purchased the car from a drug task force auction with 166,000 miles with it and the tranny fluid looks like it was never replaced while its not slipping or throwing any codes i would like to put this newer less miles transmission in. i would have the entire car i was hoping i could take engine tranny pcm and harness but it is looking like i would be incorrect
  13. #33 Re: 2004 gtp swap everything into 99 gt
    like its been said, the electronics are not the same. but you can drop that engine and tranny in there with little extra work really.
  1. L26 Top Swap 2004 Impala Ss
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 11-08-2012, 04:05 AM
  2. 2004 GT Top Swap (Lots of Pictures)
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2010, 09:54 AM
  3. Top Swap on a 2004 GP-GT 3800 SIII
    By gpcustom in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2009, 08:27 PM
  4. Engine Swap?? 2006 to 2004
    By gmangrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 09:13 AM
