I am a new GPGT owner and have been battling through a lot of issues. I am wrapping up the intake gasket job along with a tune up and ready to start battling the next issue. My dash lights, interior lights, and message center lights will flicker or pulse slightly. I think the headlights may as well,but it is not as noticeable. It does not happen all the time, but it is especially noticeable in the morning when first started in the cold. The darkness probably makes it more noticeable as well. I am thinking it may be the ignition switch wiring harness in the steering column, but before tackling it I thought I would ask. I had the alternator tested and it was good. I also noticed when I was doing the intake that the orange wire to the alternator was cut and capped with a wire nut?? Do you know why this would be? Could this be causing the issue? I have noticed that the voltage was up near 16v at times as well.
Its a 2002 GT with 3800 Series II
Thanks for any help!
-Nate
