I think i got a bad crossover pipe or something.
No matter what i do the cross over pipe isn't fitting. It keeps hitting the steering column. If i put the front manifolds in, then put the crossover pipe in, it'll hit the steering column..or if i put the rears in than attach the crossover pipe it doesn't come close to lining up with the front. Also can't get the TB back on... because it hits the crossover pipe. I believe the bends are wrong somewhere...I am truly stumped and probably not making sense.
But, also, when i put the rear header in, then attached the DP...that f*cker hangs low as heck! There's probably less than 5 inches clearance from the ground; and no im not lowered. Im about to cut my losses and return these SD and get another brand...idk tho
