Thread: Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
Results 1 to 4 of 4
  1. #1 Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
    Feb 2010
    NC
    Chats
    Hello,
    I replaced the thermostat in my 2000 3.1L Grand Prix SE yesterday. I had to remove the throttle body to get access to it. After putting it all back together, my car now idles around 3000rpm in Park or Neutral. It drops to around 2k when driving which is still a little high. I can definitely feel it taking off faster and it seems to buck a little bit here and there while driving. I did hear a loud hissing sound when I first started it up right around the throttle body area. I don't hear the hissing sound anymore, though. It justs sounds like it's running a lot harder. So my question is, would a leak around the throttle body (I did not use a new gasket and it's possible that the gasket wasn't properly seated) cause these symptoms? On the plus side, my car seemed to heat up super fast!
    Thanks guys!
  2. #2 Re: Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
    Dec 2012
    troll land
    Chats
    Get a new tb gasket.
  3. #3 Re: Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
    Feb 2010
    NC
    Chats
    Quote Originally Posted by l67ss View Post
    You were right! The old gasket was missing a huge chunk. Replaced and everything is back to normal! Thanks!
  4. #4 Re: Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
    Dec 2012
    troll land
    Chats
    No prob . Sometimes you can get away with reusing the tb gasket, kinda a 50/50 chance deal. When i bought a tb to port , the gaskit tore on rhe donor. When i pulled mine, not a flaw.
  1. what are all the reasons why my car IDLES high ?
    By turboLude in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-31-2012, 04:32 PM
  2. High idle in park and neutral?
    By Injectiongtp in forum General Tech Discussion
    Last Post: 04-18-2011, 05:38 PM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. Neutral Safety Switch replaced---Still problems
    By jokyfo in forum General Tech Discussion
    Last Post: 03-27-2009, 09:06 AM
  5. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
