Thread: Random misfire
Results 1 to 8 of 8
  1. #1 Random misfire
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Just replaced the the plugs and wires and my miss went away for a couple days and now it's missing again. I'm getting random misfire and knock sensor code on the scanner. What could cause random misfire code. I noticed one of the prongs on the coil pack was rusted when I changed the wires I cleaned than up and still have the same results. Seems to run fine under idle but runs like crap at wot. I'm gonna remove the plug wire heat shields and see what that does. I'm starting to think it may be injectors.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: Random misfire
    St. Louis
    What plugs did you throw in it? And yea, I'd ditch the plug covers.
  3. #3 Re: Random misfire
    stanford Ky
    Autolite 606's
    99 gtp- sold
  4. #4 Re: Random misfire
    stanford Ky
    Could a vacuum leak cause it to misfire? The vacuum hose around the supercharged was brittle and broke
    99 gtp- sold
  5. #5 Re: Random misfire
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    yes it could, I would suggest replacing all of your vacuum lines. its only about 4 bucks for the lines and 2 for the vacuum-T's
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  6. #6 Re: Random misfire
    I'd say its likely a coil pack issue or a ICM problem.
  7. #7 Re: Random misfire
    Mercer, Pa
    Vacum leaks are common on old high mile engines and definitely cause misfires.
  8. #8 Re: Random misfire
    stanford Ky
    Yeah I replaced some vacuume lines today and it seems to have fixed it. I got a fuel filter while I was at it. I figured since the plugs and was original the fuel filter has probly never been changed. It's amazing how people won't take care of there ****.
    99 gtp- sold
  1. 99 gp 3.1 random misfire
    By bmt in forum General Grand Prix Discussion
    Last Post: 05-22-2013, 03:49 PM
  2. Random Misfire
    By rhea0032 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 09:11 PM
  3. Random Misfire
    By SamGT in forum General Tech Discussion
    Last Post: 01-06-2012, 07:20 AM
  4. Random Misfire
    By BlackSun in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 12:22 PM
  5. Random Misfire
    By Diegogrande in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 10:18 AM
