Thread: P0301 Misfire Cylinder 1 Help
Results 21 to 40 of 41
  1. #21 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    Are copper plugs fine to use? It looks like everyone uses iridium. I only drive probably 2,000 miles a year as of now so I am looking at copper plugs.
  2. #22 Re: P0301 Misfire Cylinder 1 Help
    copper are fine. just get the stock heat range. if i knew the # id say it. im not sure what it is tho.
  3. #23 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I'm looking at ac delco 41601 and ac delco wires. Also, I swapped the plug wire from the Buick to mine and same thing happens. About halfway around the block starts hesitating and vibrating.
  4. #24 Re: P0301 Misfire Cylinder 1 Help
    being you got a parts car there, try swapping the icm and coils from your dads car.
  5. #25 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    Found out the Buick has a cylinder 4 misfire so the coil might not be good anymore. I will try swapping the next warm day. In the mean time in going to order plugs and wires. Are those plugs good?
  6. #26 Re: P0301 Misfire Cylinder 1 Help
    http://www.rockauto.com/catalog/moreinfo.php?pk=89926 acdelco is what came in the car, but it came with acdelco iridium plugs. copper are just fine tho. just dont last as long.
  7. #27 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    The AC Delco 14 plugs in my car are platinum and are heat range 3. These copper ones are heat range 4. Will this make any difference?
  8. #28 Re: P0301 Misfire Cylinder 1 Help
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Bad plug can still cause the missfire at random times. You have eliminated the wire more or less. Next try swapping the plug from the bad cylinder to one that isnt misfiring.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  9. #29 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I haven't been driving it long enough for the check engine light to come on so how would I found out if the cylinder is misfiring?
  10. #30 Re: P0301 Misfire Cylinder 1 Help
    a code scanner.
    i got a cheap one off ebay, 16 bucks shipped. shows just enough to be worth it.
  11. #31 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I have a code scanner called torque on my phone which works great. But there isn't a code because I don't want to drive it to long and the check engine light doesn't come on in the time I drive it. Is there a way I can monitor something that will show if it's misfiring? I can monitor a lot of things using this app and obd2 scanner.
  12. #32 Re: P0301 Misfire Cylinder 1 Help
    May 2012
    Where winter never ends
    Torque can watch for misses. Just add it to the display, also no need to order the plugs online, just go to an autoparts store and tell them you want those. Save shipping.
    2000 Regal - Winter Beater
  13. #33 Re: P0301 Misfire Cylinder 1 Help
    Apr 2011
    South Dakota
    *sigh* It seems no one understands the process of elimination as soon as you bring a car into the mix. Have fun.
    I love Decker<3
  14. #34 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    Frosty, my car needs new plugs and wires anyway so I ordered them. This will eliminate some possibilities that could be causing the misfire if it is still happening. If it still continues I will try to eliminate more possibilities after the plugs and wires are replaced.
  15. #35 Re: P0301 Misfire Cylinder 1 Help
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
  16. #36 Re: P0301 Misfire Cylinder 1 Help
    Jul 2013
    adrian, mi
    cylinder 5 misfire p0305. plugs are autolite 104's. plugs and wires were changed about 3000mi ago. i swapped the 5-2 and 6-3 coil packs to see if the miss would follow to cylinder 3 and it stayed on 5. also was fine this morning for about 25 minutes then started missing again. i pulled the plug to see if there was fuel getting to it and there was. also checked all the coil packs and there reading right around 5.5 ohms at the male end. help please so confused.
  17. #37 Re: P0301 Misfire Cylinder 1 Help
    try swapping a injector around next.
  18. #38 Re: P0301 Misfire Cylinder 1 Help
    Jul 2013
    adrian, mi
    that was my next move just wanted to see what other people thought
  19. #39 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    I got the plugs and wires replaced today and no luck. I drove a block and a half and everything was fine then parked to plug in torque and while I was plugging it in it started to shake and misfire. I'm going to try swapping coils with the Buick but if the coil is fine what should I do from there?
  20. #40 Re: P0301 Misfire Cylinder 1 Help
    Mar 2013
    NW Iowa
    Just noticed the site was down most of the day so I thought I should up this post.
  1. Elusive cylinder 1 misfire(p0301)
    By upsman72 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2012, 10:15 AM
  2. Misfire in Cylinder 6
    By Porach in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
