Thread: Replacing throttle cable
Results 1 to 11 of 11
TEK310 Replacing throttle cable 01-11-2014, 07:13 PM
jasonnovak Re: Replacing throttle cable 01-15-2014, 12:55 AM
TEK310 Re: Replacing throttle cable 01-15-2014, 10:37 AM
brandonl2000 Re: Replacing throttle cable 01-15-2014, 08:17 PM
jasonnovak Re: Replacing throttle cable 01-15-2014, 09:03 PM
brandonl2000 Re: Replacing throttle cable 01-15-2014, 09:37 PM
jasonnovak Re: Replacing throttle cable 01-15-2014, 09:47 PM
TEK310 Re: Replacing throttle cable 01-16-2014, 10:20 AM
brandonl2000 Re: Replacing throttle cable 01-16-2014, 07:37 PM
brandonl2000 Re: Replacing throttle cable 01-19-2014, 01:11 AM
TEK310 Re: Replacing throttle cable 01-19-2014, 08:35 AM
  1. #1 Replacing throttle cable
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Anyonre have a write up on replacing throttle cable? how do you remove it from the firewall?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: Replacing throttle cable
    Oct 2013
    WI
    I had to do this recently, I took some pictures of instructions I used.
    It's a little tricky to remove it through the firewall, you have to squeeze the "tangs" together so it fits through, but they're recessed into the padded sound insulation so you can't really see what you're doing. Do remember if I did it with needle nose pliers or two small screwdrivers. I took off the pedal, too
  3. #3 Re: Replacing throttle cable
    Mar 2012
    Dallas
    yeah sweet. I got it replaced.
    thanks
  4. #4 Re: Replacing throttle cable
    Grand Rapids, MI
    what did you use to get it through the firewall tek? how bad was it?
  5. #5 Re: Replacing throttle cable
    Oct 2013
    WI
    Sorry, the closeup from the original isn't much better:
    Basically there are two clips on each side, so when you're installing it they switch together so it fits through the hole, and once it's through they expand back out so you can't pull it back through. You get it out your squeeze the clips together and you can push it through, I used pliers I think. Couldn't really see well, just kind of stick them in there, squeeze and push, and it's it's not on the clips move the pliers a little. You should be able to see them if you look at your new cable
  6. #6 Re: Replacing throttle cable
    Grand Rapids, MI
    so when installing the new cable. does it go out from in the cabin, or in from the engine bay
  7. #7 Re: Replacing throttle cable
    Oct 2013
    WI
    When installing you do it from the engine bay and pull it into the cabin, just pull it in the clips will lock it so it can't pull back out
  8. #8 Re: Replacing throttle cable
    Mar 2012
    Dallas
    yup through the engine bay and pull through to the inside
  9. #9 Re: Replacing throttle cable
    Grand Rapids, MI
    not bad. will attempt it tomorrorw hopefully. im pretty sure its the cable. without the cables the tb closes smoothly. pullin on the cable. the last little bit has a sticky feel
  10. #10 Re: Replacing throttle cable
    Grand Rapids, MI
    Did manage to do this today as well, it was quite a pita. With the rubber insulation and the throttle pedal in the way and all the other dash bs it was quite difficult to get a bite on the clips. I ended up just taking the pedal out of the way, I got the pliers to bite, had Dan pull from the engine bay and she popped out. Mind you that was after a good few mins of the both of us trying to squeeze and push with the pliers.
  11. #11 Re: Replacing throttle cable
    Mar 2012
    Dallas
    I ended up just ripping the old one out with my man strength.
    I also took the pedal out. but I had already broke the pedal bracket
  1. How do I remove the throttle cable?
    By Boostdreamer in forum General Tech Discussion
    Last Post: 10-09-2011, 05:48 PM
  2. Replacing battery cable
    By StFarmer in forum General Tech Discussion
    Last Post: 07-28-2010, 07:45 PM
  3. Replacing Shifter Cable
    By twig123 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-21-2009, 12:40 PM
  4. connect throttle cable to pre 99 N* TB
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-30-2008, 10:52 AM
  5. Replacing the shifter cable
    By Zef_66 in forum General Tech Discussion
    Last Post: 01-25-2008, 01:12 PM
