Thread: Tip to repair broken clip on door switch plate bezel
Results 1 to 3 of 3
  1. #1 Tip to repair broken clip on door switch plate bezel
    Oct 2013
    WI
    Having to go into my door so many times I broke the clip at the top of door switch plate - I wanted to try to repair mine, especially since they're more pricey for a couple. I also had a bunch of door panel clicks to replace the ones I wore out going into the door and they appear to be a perfect repair piece.
    My broken plate...
    An original and modified door panel clip... cut off the tip and one of the discs at the top
    And finally here it is in place (no glue yet)...
    I glued it in with a bunch of "plastic weld" glue which is actually supposed to melt it a bit, will check tube in a bit. Fits like it was made for it, just the right overhang as the original clip, and the back is braced against the mirror joystick to support when putting it in the car. Been holding for a few weeks, see how it fairs when I pull it out again in the spring to replace the window regulator...
  2. #2 Re: Tip to repair broken clip on door switch plate bezel
    GT Level Member Exile's Avatar
    Chicago
    Nice fix. Already replaced my switch place once because of the broken tab...
  3. #3 Re: Tip to repair broken clip on door switch plate bezel
    Sep 2012
    Cedar Rapids, Iowa
    Nice, I replaced mine once and I actually have to replace it again now. Maybe I'll give this a try.
  1. trans swap cradle bolt retainer clip broken
    By 98regal in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2012, 01:29 PM
  2. Window clip broken, please help!
    By VejGTP in forum 04+ Specifics
    Last Post: 11-01-2011, 03:25 PM
  3. broken inj clip...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-01-2010, 07:51 AM
