Thread: Mild shuddering / shake at Idle
Results 1 to 5 of 5
  1. #1 Mild shuddering / shake at Idle
    GTP Level Member
    Aug 2012
    st louis park, MN
    Guys and Gals,
    I have an 08 grand prix base model with 97k on the clock. I have been bothered by this assumed problem since I bought my car at 30k miles. When idling in park or neutral, the car will have an intermittent shake or shudder that can be felt through my butt on the seat and or the steering wheel. For the past couple of years I've assumed it was engine related since the motor moves around a bit at idle and thought it was just transmitting that movement through the car. I've maintained the vehicle as best I can and have done regular maintenance - and in an attempt to fix the shudder I did new plugs, wires, MAF cleaning, throttle body cleaning, pcv valve replacement within the last 15k miles. None of those made a noticeable difference to this issue . Overall the car runs great and has never had any dummy lights on, not started, etc.
    The other day I realized that the tailpipe, and likely the hole exhaust system, was just vibrating at idle and was curious if this could be part of the problem. I am curious if anyone has any insight into this issue? Even more generally, should this engine feel like a sewing machine at idle or does the engine move around a bit at idle?
    Thanks to anyone that can help!
    -Joe
  2. #2 Re: Mild shuddering / shake at Idle
    It might be time to replace the motor mount and the upper dog bone mounts.
    Those can transmit vibrations if they are worn out.
    Wouldnt hurt to check the condition of the rubber hangers in the middle of the car, see they have dry cracks in them or are ripped.
  3. #3 Re: Mild shuddering / shake at Idle
    GTP Level Member
    Aug 2012
    st louis park, MN
    I will check out the exhaust hangars and make sure they are in good condition. Engine/transmission mounts have been on my mind - I'll look into them but since its been doing it since I bought the car with only 30k miles I'm not sure if they'd be acting up that soon.
    Could it be any sort of misfire if the car has always run great and never had a dummy light on?
    Thanks for the input.
  4. #4 Re: Mild shuddering / shake at Idle
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    My car has a very similar thing going on. Exactly like you described and lasts only about 2 maybe 3 seconds. I'm glad you've made this thread because I've been wondering the same things you are about what could be causing it.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  5. #5 Re: Mild shuddering / shake at Idle
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ok, maybe I should clarify a bit. What I'm feeling is more similar to a singular bump vs a 2 or 3 second vibration. It's like someone softly kicking your seat - just one bump at a time.
    Sometimes when I'm stopped in in gear and have the heater or A/C on I will get a vibration but I think that has to due with lots of draw on the electrical system. Not sure if that is what you are getting SomeDudeAtHome... that doesn't bother me as much because it goes away as soon as I turn off the fan.
  1. shuddering on take off
    By raygt2005 in forum General Grand Prix Discussion
    Last Post: 12-15-2012, 07:55 AM
  2. Mild L67 project
    By the wizard in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2012, 01:34 AM
  3. L67 mild mods
    By jsnyder49090 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2012, 11:41 AM
  4. shuddering
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-09-2009, 03:28 PM
