So what do I have to do to install them? Just knock out the old ones and pound in the new ones?
Sawzall it is .
Sawzll or something to cut that rubber out of there. There pressed in there pretty good. Now you know why the new ones are 2-peice.
Blowfish is just weak...A real man can pull them out with his bare hands....LOL
is it difficult to but stockers back in? im tired of the vibrations my upper mounts are giving me so i want to put the stockers back in. my friend put my polys in and i wasnt there to watch.
i was just going to buy some brand new stock mounts. hopefully they arent too hard to put back in.
Greased up it shouldn't be too bad to put them in. Not nearly as bad as getting them out, I'm told.
The easiest way to get the stock one out that I have found is to put the assembly in a vise and drive a sharp gasket scraper through the two solid portions of the mount along the aluminum center. I just used a few blows from a dead blow mallet to drive it through the rubber. Once both sides are cut, the aluminum center will pop right out. Then the remaining outer piece of rubber can be easily pryed out of the assembly with a screwdriver.
I cut mine with a razor blade, 2 hours later (and some split blood) the new ones were in.
Blowfish is just weak...A real man can pull them out with his bare hands....LOL[/QUOTE]
ha, aight chuck norris
I used;
-Drill
-2 Flat heads
-WD-40
-Switch Blade
2 hours later + blood, removed.
I know this thread is old but me and my dad just put the bolt back through then gripped the bolt with vicegrips and pulled that sucker out
I was thinking about going poly mounts are they worth it?
Good I think ill look into them after I fix my other problems
