Thread: Driveline vibration 02 GP GT
Results 1 to 11 of 11
  1. #1 Driveline vibration 02 GP GT
    Jun 2012
    south haven mi
    Been trying to shakedown driveline vibration that drives me crazy. It feels like a wheel is slightly out of balance but the tires have about 5000 miles on them and I have taken the car back to them three times.The last time I made them show me so I would know.It feels like the trans to me possibly but I am not sure the car has no loose or worn components at all the motor mounts seem ok I am at a loss.At 70 it vibrates the seat and door panel on the pass side on a exit ramp you can feel it fairly good and I think I hear some growling ??
  2. #2 Re: Driveline vibration 02 GP GT
    No loose front end parts?
    Kinda sounds like you may have a seperated tire or something like that, hard to say without looking at them in person.
  3. #3 Re: Driveline vibration 02 GP GT
    Jun 2012
    south haven mi
    nothing is loose in the front end tires have 5000 miles falkens and I have taken them back three times cause it feels like a bent wheel almost
  4. #4 Re: Driveline vibration 02 GP GT
    May 2013
    MN
    Warped rotors can cause vibrations the faster you go.
    2004 Grand Prix GT
  5. #5 Re: Driveline vibration 02 GP GT
    Jun 2012
    south haven mi
    the car is super clean I know that doesn't matter it had a abs light on I replaced that hub and turned out the wiring was bad I replaced all four rotors a couple months ago you feel it worst on ramps for some reason this is a dealer serviced garage kept vehicle with the original paint in very good condition no accidents
  6. #6 Re: Driveline vibration 02 GP GT
    does it vibrate when off the gas? aka coasting at highway speed? if no, it could be a bad axle.
  7. #7 Re: Driveline vibration 02 GP GT
    Jun 2012
    south haven mi
    it seems like its on the gas only I thought about that but they make no noise or anything I don't know to be honest I always think the worst I figured it as the differential
  8. #8 Re: Driveline vibration 02 GP GT
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    I hadn't driven my car in a while, and recently noticed a burning smell....ended up being a sticky caliper...who knows how long it had been that way, but I noticed obvious vibration due to it....
  9. #9 Re: Driveline vibration 02 GP GT
    Jun 2011
    Texas
    If it vibrates on acceleration and not during coast or deceleration it is a bad cv joint. Most people find the right inner cv joint is the one that goes bad most frequently.
  10. #10 Re: Driveline vibration 02 GP GT
    Quote Originally Posted by jsnyder49090 View Post
    my axle was vibrating only when light on the gas, off the gas nothing. my guess is i caught it before the clicking sounds happened. my boot never leaked grease either.
    inside that boot is a U joint type set up, feels just like a bad u joint on rwd drive shaft. if you ever felt one of them when bad.
  11. #11 Re: Driveline vibration 02 GP GT
    Jun 2012
    south haven mi
    I will try to put axles in it they are only 45 bucks a piece so its not that bad and hope for the best thanks for the input i was doing some reading on here and read that the diffs can cause this also ???
  1. Vibration
    By RICHEYSGTP in forum Brakes/Suspension/Chassis
    Last Post: 11-04-2012, 12:58 PM
  2. 2007 GT - A few questions: Driveline, Tranny
    By RotyP in forum General Tech Discussion
    Last Post: 12-07-2011, 04:36 PM
  3. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
  4. driveline vibration issue
    By nutcase in forum Off Topic Discussion
    Last Post: 01-14-2009, 03:05 AM
  5. Driveline Growl
    By Mr Book in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-15-2008, 02:07 AM
