Thread: Low Coolant Light
Results 1 to 11 of 11
  1. #1 Low Coolant Light
    Apr 2008
    Hampton, VA
    I have a stock 2002 GTP with 55000 miles on it. It's my daily driver never raced or driven hard. When I go to start it up this morning my Low Coolant Light on the dashboard was on. The rad. and the overflow both are were they are suppose to be. I let it run awhile to to if it was going to overheat, never did went through cycle just fine. Any ideas on why my light came on and stays on now. Thanks for your help.
    Scott
  2. #2 Re: Low Coolant Light
    Apr 2008
    Hampton, VA
    OH yea I also dissconnected the battery for about 20 minutes still on after that too.
  3. #3 Re: Low Coolant Light
    GXP Level Member Zef_66's Avatar
    PA
    If the radiator is full of fluid (remove the radiator cap and check it is full to the top, not just the overflow tank), then it could be a bad or clogged coolant level sensor. The sensor isn't too expensive. I am thinking less than $30. Some people have had good luck just removing the old sensor, cleaning the end of the sensor, and cleaning the hole it goes into really well. Other just replace the entire sensor and it works fine. But I would say that is your problem.
    This image might help find and remove the sensor:
    2001 GSE
  4. #4 Re: Low Coolant Light
    Apr 2008
    Hampton, VA
    Thanks I'll give it a try
  5. #5 Re: Low Coolant Light
    Donating Users Uno99's Avatar
    Appleton, Wi
    Did you park somewhere at an extreme angle? I would get that in my Trans AM when ever I park at my dads house. his driveway is at a 30degree angle.
    Otherwise I 2nd ZEF_66
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  6. #6 Re: Low Coolant Light
    Odessa, MO
    If you are quick enough with your hands, it can be done without draining any coolant. I did mine that way and lost very little, but just have it ready to go in your other hand.
  7. #7 Re: Low Coolant Light
    May 2008
    staten island,NY
    ever since i went supercharged, and you nail the gas the low coolant light comes on. rad is full, as is the res. i replaced it and still the same thing, im just going to leave it unplugged. also you dont need to remove the battery. i took out the pass. headlight and got at it just fine
  8. #8 Re: Low Coolant Light
    PA
    Quote Originally Posted by Abrasive View Post
    Yeah, you can do it without losing much coolant. But since a lot of them get gunked up, I would suggest pulling the old one and letting the coolant that comes out drain into a drain pan. Then clean out the sensor hole to make sure there is no debris in the way that could prevent the sensor from doing its job correctly (and showing a false light). Then install the new sensor.
    Just my advice.
    2001 GSE
  9. #9 Re: Low Coolant Light
    Apr 2008
    Hampton, VA
    Is this sensor something I can get at my local Autozone or is it a dealer item. Thanks again guys
  10. #10 Re: Low Coolant Light
    TDCRacing
    Guest
    O'Reilly Auto Parts - Results for Shopping Search
    Auto Parts Fast at RockAuto would probably be cheaper. Typically oreilly's is the chepest from what i have found on parts besides rockauto.
  11. #11 Re: Low Coolant Light
    I live here. UR LOSN's Avatar
    Rockford, IL
    good info in this thread!
  1. Low Coolant light - bad sensor?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2008, 08:19 AM
  2. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  3. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  4. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
