So this is going to be for my new engine build.....
ZZP XPZ at around 570 intake and 540 exhaust
Intense stage 3
Stage 3 Blower Cam, duration @ .050": 222?/228?, lobe lifts: .338"/.344", valve lifts with 1.60:1 rocker arms: .541"/.554", lobe separation angle: 115?, intake centerline: 111? (+$50.00)
I Want the most power. And the simple answer to that might be the cam with the highest lift. But the dyno numbers i've seen are very very close with the 2 cams above.
Also considering the stage 4 from intense
