It's a little cold here in North Central Illinois and the wife has been without heat now for about two weeks. 97 GTP with about 230K on her now. I've replaced the motor and resister twice in the last week (on the off chance got bad parts from AutoZone) with no success. Tried the ignition power bypass as well http://www.clubgp.com/newforum/tm.as...key=&language= in case it was an issue with power. No luck with that, and I have verified power to the resistor and everything. Verified all the fuses were good as well. Everything has power, seems to have no ground. Came to the conclusion that it was the fan switch so I picked one up at a yard and just tried with still no success.
Anyone have any other ideas, I'm out at this point, and all my searching keeps leading back to the same things that I've already tried and with temps hovering in the 20's through the day, its something I need to get fixed.
