Thread: Weird Rubbing noise when making a hard left turn
Results 1 to 5 of 5
  1. #1 Weird Rubbing noise when making a hard left turn
    GT Level Member K Kraziee's Avatar
    Apr 2013
    Milwaukee
    I've had this problem for awhile, it seems my passenger front tire is rubbing against something when I make a hard left turn. I recently got new tires and it still makes this noise so I'm thinking it's in the suspension somewhere. Any help would be appreciated.
    DD: 2000 Pontiac Grand Prix GTP
    3.5 ZZP MPS, HAI, ZZP Ported Throttle Body, PLOG, 3" Catless DP, Water pump and Alt. UD Pulley, Custom Tune
  2. #2 Re: Weird Rubbing noise when making a hard left turn
    look for rub marks in the fender well and on the tire.
  3. #3 Re: Weird Rubbing noise when making a hard left turn
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Best guess would be your inner fender may be loose. Do what scotty said and check for rub marks
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: Weird Rubbing noise when making a hard left turn
    St. Louis
    Check the splash shield that cover the balancer and A/C pulley. Likely the bottom edge of it is not tucked up on top of the control arm.
  5. #5 Re: Weird Rubbing noise when making a hard left turn
    Apr 2013
    Milwaukee
    Ok, I'll check all these area's. Thanks
  1. 04 GP GT2 WT, Shifting hard & Making a wining noise (OMG! WTF! IS THIS?)
    By DemonNo13 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2013, 02:50 PM
  2. 04 grand prix supercharger making whinning noise when turn steering wheel ...
    By elizabeth8790 in forum Introductions/Noob Questions
    Last Post: 02-12-2013, 08:42 PM
  3. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  4. m90 making weird noise
    By gtp239 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2011, 12:32 PM
  5. Rubbing noise from front left tire
    By zeppelinrocks18 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2009, 05:45 PM
