Thread: fuel line
Results 1 to 10 of 10
  1. #1 fuel line
    Dec 2011
    Cortland
    Its freezing out and I don't have access to a lift until later so...?does anyone know if the lines coming off the gas tank are accessible without having to drop it? Gotta replace all of them unfortunately
  2. #2 Re: fuel line
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    More info would be good...
    Year and type of car for one.
    Some more background on what you think your problem is would also help.
  3. #3 Re: fuel line
    Dec 2011
    Cortland
    97 Buick regal. Basically need to have the parts before I work on it since the lift my bud has won't be open until 9. I'm wondering if I can access the lines off the gas tank and also how to replace the nylon lines coming from the fuel rail to the metal rail. The nylon line looks almost like its heat shrinked. Basically just need a part list for fuel lines from gas tank to front. Not going to worry about replacing the evap line though
  4. #4 Re: fuel line
    Dec 2011
    Cortland
    Also thanks for the quick reply. If you need anymore info or I'm not being clear enough just let me know
  5. #5 Re: fuel line
    Dec 2011
    Ontario,Canada
    I believe Dorman has kits which you should find at the parts store to replace the line to rail fittings.
    Look behind your rear seat in the trunk, there will be access panel to get at the pump and lines that connect at the fuel tank.
  6. #6 Re: fuel line
    Dec 2011
    Cortland
    Do you know offhand if the lines coming off the tank are metal or nylon?
  7. #7 Re: fuel line
    Dec 2011
    Cortland
    Wouldn't I have to order a part from doorman? I need this done by tonight which limits me
  8. #8 Re: fuel line
    Dec 2011
    Cortland
    I'm looking at using metal lines right now but am not sure how to connect from a metal line to the lines at the gas tank side and how to connect the metal lines to the nylon lines that go to the fuel rail. That is a better way of wording it haha
  9. #9 Re: fuel line
    Dec 2011
    Cortland
    Nobody going to help me out? . If someone is going to reply please do so soon
  10. #10 Re: fuel line
    You'd have to drop the tank to gain access to all the fuel lines.
  1. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  2. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
  3. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
