Thread: car won't start
Page 7 of 7 FirstFirst ... 567
Results 121 to 135 of 135
  1. #121 Re: car won't start
    GT Level Member al2000gtp's Avatar
    Buda,IL
    I can check compression though
  2. #122 Re: car won't start
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    You can get a bypass pully off ebay for 40 bucks. And you can get a new clutch-bearing for the same. A small puller isall you need. If you decide to change the entire compressor you will need to change the expansion valve and dryer as well. Ck the new compressor to see if it already has oil in it, some do., ifso don't add any.If you have access to a vacuum pump you can do the whole thing yourself. I changed compressor on my Freight Liner.
  3. #123 Re: car won't start
    Buda,IL
    Its the harmonic balancer not the ac compressor.
  4. #124 Re: car won't start
    oh lewis.......wrong thread maybe?
  5. #125 Re: car won't start
    Buda,IL
    Well may be doing that big build after all. Lol.
  6. #126 Re: car won't start
    Yay
    04 Comp G.
  7. #127 Re: car won't start
    Buda,IL
    I can't see to much up around the flex but it def. Isnt moving when you try to tighten the bolt. Not looking to good. Still haven't checked compression and prolly won't tonight but ill do it tomorrow. The mechanic who installed the engine is also coming over tomorrow. He wants to here it try to start cuz he doesn't believe that the hb could be moving and the flex isn't
  8. #128 Re: car won't start
    Buda,IL
    Well mechanic came over today and said seems like a broken crank to him too so I'm getting another engine and he's doing the work all for free. Thank god for warranty lol. Ill have to go a couple more weeks without the gtp but feels good to know everything is covered.
    I just need to hit the jy for another egr tube cuz I deleted mine and don't want that to void warranty
  9. #129 Re: car won't start
    do get some pis of the engine with the pan off, id like to see a busted crank. one thing neither i nor my friends ever broke.
  10. #130 Re: car won't start
    Buda,IL
    Lol I can't believe it broke at 15 mph. Hope the next engine doesnt do the same to me.
  11. #131 Re: car won't start
    it still comes down to "if" its broke, its so rare, usually takes some big HP to bust one, with a rod and a piston through the head, aka some major carnage.
  12. #132 Re: car won't start
    Buda,IL
    Yeah he said maybe it isn't broken and the thrust bearings went out
  13. #133 Re: car won't start
    I've never heard of a broken crank on one of these 3800's. I've seen rods in pieces, pistons in the pan.. even holes in pans. Just never a broken crank. However with your symptoms..there really isn't much else.
    You asked about metal in the oil. When you kill a bearing and it wears away..that metal flake is in the oil. When you break something big..you might have large chunks that won't fit through the drain hole.
    I'm honestly very interested and would like to see pics.
  14. #134 Re: car won't start
    Buda,IL
    Yeah I told him I wanted to be there when he pulls the pan so I could see it and ill def get some pics and post em.
  15. #135 Re: car won't start
    Sep 2013
    tulsa okla
    Indeed it was the wrong thread Scotty
  1. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  2. what to start getting for my 07 GXP
    By rockbassray in forum General Tech Discussion
    Last Post: 10-16-2012, 05:11 PM
  3. car will only start in N
    By rich1 in forum General Tech Discussion
    Last Post: 11-23-2011, 01:49 PM
  4. Rev's at start up
    By 2003GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2010, 06:58 PM
  5. where to start
    By krimsonwolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 05:03 PM
