Thread: Battery drain issue
Results 1 to 19 of 19
Threaded View
Sandman Battery drain issue 10-30-2013, 06:04 PM
02NavyBlue Re: Battery drain issue 10-30-2013, 06:08 PM
Scottydoggs Re: Battery drain issue 10-30-2013, 06:12 PM
Sandman Re: Battery drain issue 10-30-2013, 06:35 PM
Scottydoggs Re: Battery drain issue 10-30-2013, 07:12 PM
matt5112 Re: Battery drain issue 10-30-2013, 07:28 PM
Sandman Re: Battery drain issue 10-30-2013, 07:37 PM
Scottydoggs Re: Battery drain issue 10-30-2013, 07:52 PM
primem Re: Battery drain issue 10-30-2013, 08:02 PM
Sandman Re: Battery drain issue 10-30-2013, 08:05 PM
tech3627 Re: Battery drain issue 10-30-2013, 10:48 PM
02NavyBlue Re: Battery drain issue 10-31-2013, 10:40 AM
Sandman Re: Battery drain issue 10-31-2013, 12:09 PM
02NavyBlue Re: Battery drain issue 10-31-2013, 03:55 PM
Scottydoggs Re: Battery drain issue 10-31-2013, 04:26 PM
Sandman Re: Battery drain issue 10-31-2013, 04:32 PM
Scottydoggs Re: Battery drain issue 10-31-2013, 04:34 PM
Sandman Re: Battery drain issue 11-01-2013, 06:35 AM
02NavyBlue Re: Battery drain issue 11-01-2013, 11:49 AM
  1. #1 Battery drain issue
    Jan 2009
    Tallahassee, FL
    I've got a battery drain issue where by lunch time my car is tough to start but once cranked it's all good. I've looked over the battery cables and can't find anything wrong with them and I did a drain test by hooking my meter between the battery ground cable and terminal while pulling fuses and never saw any differences. I didn't do a detailed look but I did a quick glance around the engine bay and the wires looked good. I'll get in there this weekend and really look everything over. Also I've read something about the alternator diodes going bad and pulling power but I disconnected the alt entirely and no change. It is pulling about .144 amps, I'm assuming that's to high. What else can I do to find this?
    edit:
    I forgot a bunch of info there. The battery is new, starter is new, alt is the stocker @ 170K miles, the battery grounds are clean, I pulled fuses from both fuse panels, and the meter I'm using is a regular Fluke with the probes.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Constant Electrical Drain Running Down The Battery
    By falcongt in forum General Tech Discussion
    Last Post: 11-06-2017, 07:09 PM
  2. Battery Drain
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 05-19-2013, 05:31 PM
  3. confusing battery drain...help!!!
    By twol8uluz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 01:48 PM
  4. HID Battery Drain
    By Lishap in forum 04+ Specifics
    Last Post: 06-18-2012, 11:53 AM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
