Thread: Heat and AC issue
Results 1 to 3 of 3
  1. #1 Heat and AC issue
    Mar 2013
    Bridgeville, Delaware
    Have not been here in a while, so Hi to all.
    I have a 98 Pontiac GP GTP. I have the dual inside Temp. controls. During cold periods one blows out the heated air, but other side is cold, during warm periods with AC on it's the opposite. What could this be?
    awk
  2. #2 Re: Heat and AC issue
    St. Louis
    Let me guess, the drivers side is the one that is acting up? Either way, sounds like a broken temperature actuator. Pretty common on the dual climate systems.
  3. #3 Re: Heat and AC issue
    Mar 2013
    Quote Originally Posted by FordMan77 View Post
    Yes. Like right now with temp. turn up on both sides, the driver's side will get no heat at all, just cold air, pass. side has heat. AC on, the driver's side has ac, but not pass.
    Is the is actuator easy to locate, where might it be.
    awk
  1. A/C & Heat Vents Issue? 99 GT
    By corxbeans in forum General Grand Prix Discussion
    Last Post: 06-17-2013, 10:45 PM
  2. No heat on drivers side, but heat on passenger side.
    By maceman in forum General Tech Discussion
    Last Post: 04-05-2013, 06:57 PM
  3. Help! No heat, blower motor issue???
    By lks28 in forum General Tech Discussion
    Last Post: 11-21-2012, 11:19 AM
  4. Heat issue?
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 12-18-2010, 03:01 AM
  5. Help! Heat issue
    By mpatton22 in forum General Tech Discussion
    Last Post: 09-27-2010, 05:47 PM
