Thread: My latest custom project- 4T80E swap in our 1997 Grand Prix UPDATE- Its on the road!
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 84
  1. #41 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Once the tuning issues are worked out along with whatever rack issues thrre maybe this needs a how to/sticky thread! 1
  2. #42 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Nov 2011
    NY
    Subbed!
  3. #43 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Dave we would all love you forever if you made us a kit to do this once you finish. Me and several of my pals would scoop it up right away.
    04 GTP -HAI, 1.9 rockers.
  4. #44 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    May 2012
    Albuquerque, NM
    I just called in about a built tranny but I'd happily be your next experiment AND I would even pay to play!
  5. #45 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    I live here. DirtDog's Avatar
    Jun 2012
    .........subbed as well for awesomeness
  6. #46 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Thanks guys. Not much to update the past week or so on this. Starting on wiring- this is a 97 car and due to the relocation of several things I am pretty much rebuilding an entire harness to work with all of this. That is not something necessary for the conversion, just something I am doing to best fit the engine layout.
    Transmission shift linkage bracket and lever were made to work with the factory cable and stay clear of the turbo so that is covered.
    Axles have been sorted out and is a simple drop-in solution. There were really only 2 main axles used in the vehicles that had the 4T80E transmissions and these vehicles all used the same axle both left and right side. A main stream Caddy/Aurora/Bonneville GXP axle length was a great fit on the drivers side. The Eldorado and a few other models used a shorter axle which turned out to fit great on the passenger side. The outer end of these axles is the same as the Wbody so nothing needed to be done with them, simple solution.
    The throttle body and battery arrangement has been finalized and I can retain keeping the battery in the front, just turned 90 degrees from stock location to give a little more room for the inlet tube to the throttle- which will now be located in front of the fuse and relay box due to this being an Fbody intake. This is a 99+ style Fbody upper intake which used a drive by wire throttle body, though I am using an L67 throttle body which works with stock throttle cables and also will work as the stock cable is very long and wrapped around the strut tower so gives plenty of length to move to the other side. I found that moving the fuse and relay box backwards about an inch opened up a bit or room and clearance for the throttle body to fit here, lots of chewing on ideas and relocation but turned out to be a very easy fix.
    After wiring is finished up I need to build a rear manifold/header and fab up the new crossover pipe to feed the turbo. Since I have the throttle body on the passenger side it opens up a lot of options for a front mount intercooler. A Tru-Cool maxi cooler transmission cooler will be fitted just above the intercooler which is what I have been using for the LS4 V8 turbo cars and works very well.
  7. #47 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    hangover park IL
    i knew it!
    sweet then i have everything i need! i have 1 set of early and 1 later 80e, took em all home with me after finding the collapsed lengths different
    you dont think there's a third length out there do ya? we really wanna tuck the rear inward more since we dont need to turn but we do need Wiiiide tires lol
    i wanna see more pics up 'er skirt, pleeeeaaasssseeeeeeeeeeee
    ~James~ Psychotic Gearhead
  8. #48 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Aug 2013
    Sandy, UT
    Coming along nicely! Keep up the good work!
  9. #49 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    May 2012
    Where winter never ends
    update?
    2000 Regal - Winter Beater
  10. #50 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    GTP Level Member joshv's Avatar
    canada
    subbed for boss sauce :s
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  11. #51 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    Engine wiring is now finished just need to go over harness with loom. New battery tray came in so that is mounted and I am working on building the throttle body adapter and then on to building a new rear manifold and turbo piping.
  12. #52 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    May 2012
    Sweeeet! How hard is the PCM programming going to be? What is going to have to change? Also, do you know if there will be a kit/write up for this. I want to do this for my turbo build :P
  13. #53 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Arizona
    im still confued about moving everything foward an inch? and how that affects axles and everything else?
  14. #54 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    The pcm tuning will be a bit of work to first get everything ironed out but I already have support to make the changes needed for the trans. The 4T80E is actually similar to a 4T40E electrically so it was just a matter of verifying several things. Until it starts and drives I won't know for sure as it is going to take a bit of tweaking to work correctly just as I ran through building a RWD L67 file for my 86 Cutlass.
    The engine moving forward an inch isn't hurting anything and the axles are very straight in the car. Something else to keep in mind- when guys lower these cars they often run a shorter upper dogbone to pull the engine/trans forward to put some angle back into the axle to eliminate a high throttle vibration. This isn't all that far different and the trans is larger anyways so part of that is offset. The back of the transmission is huge compared to a 4T65E so there is really no choice since you cannot go any farther backwards with it. If it turns into an issue then new controls arms will have to be built to move the ball joint forward the difference but I don't see any issues at this stage.
  15. #55 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Feb 2009
    flintnasty MI
    Considering that required zero tweaking, Im afraid you are going to have problems with the 80e controls.
    Bonus is, if you cant get the PWM stuff working, you can just leave it on full pressure all the time.. unplugged...
  16. #56 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Arizona
    Why on earth would you run full pressure all the time? I could see at the track but anytime else that would be horrible to drive at max pressure
  17. #57 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    hangover park IL
    zero tweeking? even i had to do some finagling on both the tune/wiring sides to control the 700r4 for tcc lockup and as my only vss feed
    i really didnt wanna do a manual switch for the tcc.
    80e controls arent a major problem especially if he found the trans value that switches the shift solenoid logic.
    the PWM/pcs havent had a problem at all even at the different frequency, its still limiting current and thats tunable, stock values on the low end are actually a bit harsh with the 80e
    ive got several 4t80e pcms that ive wanted to read fer years but never was able to
    found out that PI does 4t80e converters
  18. #58 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    May 2012
    Awesome. Well I have a car that is going need a trans, so if you ever want a 4t80 04+ Guinea pig... Im here
  19. #59 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Fort Wayne, IN
    And guess who worked with them to lay out a custom 4T80E / 3800 S2 converter option.
    TCC controls are of no concern on the 4T80E. There is no TCC pressure switch in a 4L60E or 4L80E either, pwm will work fine. There is a switch option to use or not use the TCC switch in the pcm code. Shift solenoid state gets reversed. After that it is simply plugging in new iss and vss values to get the ratios correct. Getting the trans tuned with a 3800 pcm is a non issue for this project or I wouldn't have done it.
  20. #60 Re: My latest custom project- 4T80E swap in our 1997 Grand Prix
    Arizona
    Quote Originally Posted by Trannyman95 View Post
    What about this trans working with the t42 controller ? Seems most tables you mentioned are in out tunes as well. (Ls4)
  1. Check out my latest project...
    By Confusingboat in forum Off Topic Discussion
    Last Post: 06-23-2011, 05:20 PM
  2. 1997 Grand Prix GT- L67 Swap question(s)
    By kc50lx in forum General Tech Discussion
    Last Post: 04-02-2011, 07:53 PM
  3. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  4. Motor Swap in 1997 Grand Prix GT Coupe L36
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2009, 06:00 PM
