Thread: 1.3°kr
Results 1 to 18 of 18
  1. #1 1.3°kr
    Jul 2013
    adrian, mi
    so I've got a 98gtp 104's, 3"dp, open cone, 3.4mps, 180° tstat and 1.0 pcm. is 1.3° of kr ok to deal with until I get headers and 1.9rr?
  2. #2 Re: 1.3°kr
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Put on a bigger pulley or drive like a grandma.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: 1.3°kr
    Ohio
    Ehh 1.3 aint bad.
    Car has more stock.
  4. #4 Re: 1.3°kr
    1.3?* on 3.4" pulley is nothing to worry about. over a long time, maybe.
    for now? eh.
  5. #5 Re: 1.3°kr
    gardner,mass
    Its probly only when it shifts. If your worried about it throw some octane booster in when you fill up, problem solved.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: 1.3°kr
    Quote Originally Posted by Ginseng View Post
    That will do nothing
  7. #7 Re: 1.3°kr
  8. #8 Re: 1.3°kr
    Jersey
    surprised you only have that. what gear what rpm and what speed?
    16' wrx sti- stock
  9. #9 Re: 1.3°kr
    I wouldnt care at all about 1.3º, maybe at 2 or more with a 3.4, then I'd worry more.
  10. #10 Re: 1.3°kr
    Feb 2009
    flintnasty MI
    If it lasts for more than a few seconds and is really steady. .. you have major problems
  11. #11 Re: 1.3°kr
    GTX Level Member crbquist's Avatar
    Massachusetts
    I use to see blips of up to 3* on my cammed/gen V 3.4 setup. I always felt some was false however... I wouldn't worry about anything under 2* if it comes and goes... If you have consecutive KR throughout the rpm range, then it may be something to look into.
  12. #12 Re: 1.3°kr
    Feb 2009
    flintnasty MI
    Octane booster is pretty awesome. Alot of octane booster out there will get you up over 98 octane pretty easily.
  13. #13 Re: 1.3°kr
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    ^ How much is a lot? a couple gallons? Octane booster is usually stated to add somewhere around 7 to 9 "points" of octane from one bottle. That means you go from 93, to 93.7
    04 GTP -HAI, 1.9 rockers.
  14. #14 Re: 1.3°kr
    Feb 2009
    flintnasty MI
    by alot I meant "a lot of" brands will actually do a good job of raising octane, while others will play the "points" game and raise you .xxx octane... NOS brand typically lives up to the 5-6 octane gain it adverts, so 93+6 = 99 octane... I have used some stuff guys run in offshore cigerette boats and stuff too, that is pretty good although I forget the brand (it wasnt too cheap either).
  15. #15 Re: 1.3°kr
    gardner,mass
    Really?
    This^ i am showing knock on my car due to dropping the pully and not retuning yet. I was getting 3-4 degrees, threw in a bottle of offroad nos and kr gone.I work at parts store and i sell the stuff for 19 bucks but my cost is 8 so **** it, for now on fill ups ill throw that in untill the tune.
  16. #16 Re: 1.3°kr
    it's easy enough to mix a little race gas and add it to the tank.
  17. #17 Re: 1.3°kr
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Lol octane booster... Ill be honest if I see less then 2 and its not consistent I don't even care. I run a 2.8" setup and I regularly see 2* on shifts. I just say "**** you" and keep going.... ask SnowTh1ef. He is running a bastard 3.4 setup tuned on a narrowband with literally no supporting mods other then e85 and injectors on a fully ported blower... Oh did I forget to mention ITS A HIGH COMPRESSION TOP SWAP?!?! Bursts of Kr are part of his daily drive. It scares me. Stupid Bonneville.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  18. #18 Re: 1.3°kr
    Aug 2013
    Sandy, UT
    ^hehe.. yeah. running strong tho!
