Re: Getting KR with torque app
Regarding the torque app and ELM327 combo, I don't think the ELM is the weak point. Our car has a baud rate of 10.4kb/s for VPW over a serial bluetooth connection that should be able to pump out 119.2kb/s. The torque app running on the phone simply does not have enough processor allocation to do all the calculations it needs. A dedicated module (such as a scangauge) does a much better job, because that's all it does.
M7x350z
For people who know how the app works, I had 4 knock events. What does this mean?
You serious?
It means the pcm recorded knock at 4 different times. That could be concurrent or non...
App is pretty simple and contrary to post here is certainly able to keep up with monitoring and then sending information to app and displaying it on your phone.
The caveat is this: what phone, old or new, what version ELM BT unit, how many apps running on phone and how many different things are you monitoring and or recording with Torque??? It's all relative.
I have used torque for quite a while, and side by side with physical dedicated gauges such as wideband and it works just fine.
There is no defining criteria as to when you SHOULD see knock as some have it and some don't at all ranges of rpm or mod levels.
