Thread: Steering wheel noise
Results 1 to 8 of 8
  1. #1 Steering wheel noise
    SE Level Member juicestain100's Avatar
    Feb 2010
    WISCONSIN!
    2006 Grand Prix, base. 136k miles, problem free car. Absolutely love it. Recently though it has started making a weird noise coming from up close to the steering wheel. It's not real loud, but when you turn the wheel it just sounds like a rubber on rubber noise, or possibly some sort of plastic rubbing onto something. Any ideas at all? Still steers perfectly and smooth, just an annoying noise that I don't want to escalate.
    I know I did I crappy job explaining it, hoping someone will have had the same thing though and know what Im talkin bout
    thank you all in advance
  2. #2 Re: Steering wheel noise
    GTP Level Member
    Aug 2012
    st louis park, MN
    Is it a really quiet squeek? I have a really quiet squeek in mine that seems to come and go.
  3. #3 Re: Steering wheel noise
    Dec 2012
    Where 4T65E's were born
    It's either the strut mount bushings/bearings or something wrong internally in the rack. Jack it up and tun the wheel side to side and see if you hear it with the suspension unloaded. If so have someone turn it and you'll find it.
    Sold.
  4. #4 Re: Steering wheel noise
    Feb 2010
    WISCONSIN!
    I don't think its the strut mount bearing, from watching youtube videos that seems to always make a clunking noise, no? This isn't like that at all. It's just a constant real faint quiet rubbing noise when turning the steering wheel, just like something rubbing...hmmmm
  5. #5 Re: Steering wheel noise
    Feb 2010
    WISCONSIN!
    Any more ideas? Going to bring it to a mechanic next week if other grand prixer's here can't help Dont let me down Pontiac nation!
  6. #6 Re: Steering wheel noise
    Dec 2012
    Still try what I said. When I turn my wheel even with it up in the air, it makes a squeaking noise. There has been so many people posting about this noise lately, I keep wanting to get a video of mine.
    Sold.
  7. #7 Re: Steering wheel noise
    Jun 2011
    Texas
    Most likely it is were the steering shaft runs through the firewall. You should be able to lube the area with some WD40. You can remove the lower cover on the drivers side by the brake and gas pedal and see the area. You should be able to touch the rubber boot while turning the steering wheel to confirm that is where the noise is coming from. It is possible it is a bearing in the column, but I would lube the pass through boot first.
  8. #8 Re: Steering wheel noise
    Feb 2010
    WISCONSIN!
    ^^^ That is what it is! Thank you so much! The pass through boot!
  1. 04 grand prix supercharger making whinning noise when turn steering wheel ...
    By elizabeth8790 in forum Introductions/Noob Questions
    Last Post: 02-12-2013, 08:42 PM
  2. steering wheel noise
    By carlover89 in forum General Tech Discussion
    Last Post: 12-10-2011, 12:44 AM
  3. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  4. Steering Wheel Noise?
    By 96brougham13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:32 PM
  5. steering noise HELP
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2011, 01:28 PM
