Thread: Heater not heating
Results 1 to 7 of 7
  1. #1 Heater not heating
    London Ontario
    Heater not heating. Blower works but no heat. 2006 grandprix GT with supercharged engine. Just had oil change and checkup for "check engine light" with nothing showing in codes. Where to start?
    Tx
  2. #2 Re: Heater not heating
    Check to make sure its full of coolant and if it is start with changing the thermostat since that's a cake easy job to do and its like a 3 dollar part and see if that fixes the issue. Thermostats stick and the cooling doesn't go open loop and the thing wont blow hot air. Ive changed plenty of thermostats just because the car only had warm air in the winter. It usually works especially if it blows but the air is cool.
  3. #3 Re: Heater not heating
    London Ontario
    Checking the coolant is easy, but I am not sure where the thermostat is located. I imagine it isn't hard to change out either.
  4. #4 Re: Heater not heating
    where the top radiator hose goes into the lower intake is where the thermostat is. There is 2 10mm bolts I think holding it down and has a bleeder screw on top of it. If your standing at the front bumper looking at the engine bay its on the drivers side of the engine in front of the throttle body.
  5. #5 Re: Heater not heating
    http://www.youtube.com/watch?v=2APv8zw86I0
    you do not need to take the hose off the neck! Just take the 2 bolts out holding the thermostat neck down and replace it. That will save you from screwing around putting that hose back one and them clamps can be a pain in the ass too.
  6. #6 Re: Heater not heating
    Quote Originally Posted by bluegirl View Post
    Tx
    pop the hood with the engine up to operating temps, theres 2 hoses off the alt bracket to the fire wall, carefully touch them both, if they are both hot, thats good, if one is warm the other cold your heater core has air in it.
    take those 2 hoses off the alt bracket, put a garden hose to one hose and flush it till a steady stream of water comes out the other hose, then put it back on.
    if both hose's are hot like they should be, the blend door actuators could both be bad. http://www.grandprixforums.net/showt...door+actuators
  7. #7 Re: Heater not heating
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Did replacing the T-stat fix your problem? I also have the same issue with my wife's 2007 GP. It's been blowing "luke-warm" air for a week or two. Wondering if it's the same problem?
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  1. Heater not heating properly
    By markies in forum General Tech Discussion
    Last Post: 12-18-2012, 11:46 AM
  2. Replies: 3
    Last Post: 02-15-2012, 05:23 PM
  3. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  4. heating
    By aaddonis in forum General Tech Discussion
    Last Post: 12-27-2010, 06:57 PM
